hey guys i drive an 2007 ford mustang and my current setup consists of a Mac Mini, i currently do not own an amp, so i will be wire the speakers via the stock head unit. However i have not the slightest clue how i'm going to do this. I've searched the boards but haven't really found anything to help me with my particular situation.
If you guys know a good thread that could explain how to go about this that would be great. Some questions i had was how would the stock head unit be powered? Directly to the battery i'm assuming, but the HU connector has following wires
12v line from the battery
12v acc line
Ground
Lines out to the speakers (usually 4 pair or more)
Other miscellaneous wires for various other functions
If i don't cut the connector off altogether will i need to tap into the acc line? I'm under the impression that this is the only way to go since cutting off the connector would cut power to the head unit and the head unit can't be powered by my psu right?
p.s. the stock headunit has a "line in" which allows you to connect an ipod. It looks like the mac mini line in can plug into this, any thought
stock HU looks like this, will try to get pictures of actual wiring
