I have to do some chopping and changing of cables because I have the kenwood KNA-G510 navigation unit (which is basically a Garmin GVN-53) but it has the added capability of being used in a touch screen capacity with kenwood head units.
The problem with the kna-g510 is it has a Kenwood RGB navigation plug 13 pin I/F (KHD-5L1) which is used to plug directly into the kenwood brand of head units. This is no good as I have the alpine head unit which accepts a different looking plug the, NVE-N077 which is also 13 pin.
There is also a nice diagram of the pin out configuration for the NVE-N077 on this website
http://www.mp3car.com/vbulletin/vbim...img&imgid=3299, which shows which is what wire and what it does...
So initially I thought to order a replacement wiring harness for the garmin gvn 53 (garmin part number 010-10826-02) that will plug directly into the kenwood kna-g510 and use this harness to connect to my AUX inputs on my Alpine IVA-W200E head unit. I would also need to use the garmin remote control in order to control the navigation system (garmin part number 010-10826-01).
I still need to confirm whether the garmin remote control will work with the kenwood KNA-G510 - considering that the kenwood navigation unit is designed to work directly with a touch screen kenwood interface I'm not sure that it will work.... But I will confirm this - or if someone knows if they could let me know that would be GREAT
But then I started thinking, hmmmmm, I have a 13 pin kenwood output plug from the navigation unit, I wonder if it will could possibly be manipulated to be used with the Alpine 13 pin RGB navigation plug??
I found a few interesting threads on this website about trying to use the alpine RGB navigation input to gain access to the LCD screen which makes me think that it should be something that is not too difficult - in theory I should be able to get a picture from the kenwood / garmin navigation unit the difficult part will be whether or not the Alpine head unit can control the navigation unit - if it can be done at all...
I guess what I'm really looking to build is a cable that will go from either garmin's GVN-53 RCA cable to alpine's RGB navigation input OR go from kenwood kna G510 RGB cable ( I think it is an rgb output configuration) to alpine's RGB navigation input..... Which I think is an alpine KCE-030N cable but in reverse ~ I think....
I guess the first place to start would be to try and get a wiring diagram of the outputs of the kenwood / garmin navigation unit, which I found here:
http://www.garmin.com/manuals/GVN53_...structions.pdf
I know it's now exactly the same as what I have in terms of outputs (however on the bottom of the kenwood unit it does say GARMIN GVN 53) but if we can somehow hook these outputs up to the alpine 13 pin RGB navigation inputs then we will be in business!
Anyway, let me know what your all thinking...
