Quote: Originally Posted by
FusionFanatic
are you looking to install component speaker sets? or install separate speakers and tweeters?
components come as matched sets with their own crossovers. if you buy separate tweeters, then they will usually have their own high-pass filters on them. is not necessary to buy a crossover, but if you do it will make your system sound better by sending the high frequencies only to the tweeters (otherwise the high frequencies will be reproduced by both the speakers and tweeters).
as for wiring 8 speakers (4 full range speakers and 4 tweeters) to a 4-ch amp, you simply wire each set in parallel. each amp channel would be driving both a speaker and tweeter. NOTE: when you wire speakers in parallel you cut their impedance in half. pay attention to the speaker/tweeter impedances and the amplifier's minimum impedance rating. most class AB amps are 2-ohm stereo stable, and most car speakers/tweeters are 4-ohms each; wiring them in parallel will present the amp with a 2-ohm load per channel (so in most cases you should be fine).
for your subwoofer; you can either buy a separate amplifier, or buy a 5-ch or 6-ch amplifier to power everything from a single amp.
well well , I have
Infinity Reference 9613i 6"x9" 3-way as rear speakers
Infinity Kappa 63.7i 6-1/2" 3-way as front speakers in the front doors
2 tweeters in the front doors too.
2 Stock speakers in the back doors
2 tweeters in the back doors too.
JBL CS60.4 4 Ch 240 Watt Full Range Amplifier
Currently the back doors speakers and the 4 tweeters are disconnected.
I want to have surrounded system.
6 channels amps are rare and expensive and the HU has 4 RCA only
I just want to understand the correct way to connect such surrounded system as I don't see many people have 6 channels amp.
I hope I could explain.
