Old 10-21-2008, 12:54 PM   #1
mr_sarge is on a distinguished road
Alpine Head Unit vs MP3 ID3 Tag
Hi,
Hi have an Alpine CDA-9835 Head Unit. It is supposed to be able to display ID3 Tag from Mp3 file but it always display "NO SUPPORT"
I have verify that all the mp3 on the disc have ID3 v1 and v2.3 tag and that they do not contain special caracter like ( ) ' , ect, ect.
Thay are juste A-Z, a-z and 0-9 and still having the issue.
Does someone has this problem to with this HU or another Alpine HU ?
Thanks,
François
mr_sarge is offline   Reply With Quote
Old 10-21-2008, 01:54 PM   #2
thekl0wn's Avatar
thekl0wn is on a distinguished road
If you're on a Windows-based system, can you verify that the Window's metadata tags are there? (in MyComputer, go to the folder the files are in and selected the "details" view, and right click the column headings and select a few items like "artist", "album", and "Song Title".)
I'm not sure what the head unit actually reads, the ID3 or the other metadata.
Also, are you burning your CD's as an MP3 CD or are you simply burning a CD with MP3's on it as data? This WILL make a difference!
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
thekl0wn is offline   Reply With Quote
Old 10-21-2008, 02:22 PM   #3
Metadata are there. All fille have title and artits in the apropriate column.
I'm burning as a data cd. CD-ROM (ISO) in Nero. I don't find "mp3 cd" in nero burning rom. I only found it in Nero express. Have compared the ISO format between CD-ROM (ISO) and CD-ROM (MP3) and it seam to be the same thing.
Old 10-21-2008, 04:46 PM   #4
thekl0wn's Avatar
Seems like I recall XP actually coming up and asking about this if you simply drag and drop files onto the CDR drive, and click "Burn these files".
Old 10-21-2008, 05:45 PM   #5
I've tested the Windows XP burn Wizzard. It ask if I want to make an audio CD but if I choose that, it open windows media player and try to burn 6 or 7 audio CD of 80min.
If I try Data CD, Tag don't work.
Old 10-21-2008, 06:27 PM   #6
Tested Nero Express -> Audio CD -> MP3 CD
same thing, no tag.
Old 11-05-2008, 11:12 AM   #7
Nobody have alpine head unit with mp3 tag problem? or if they work, how do you burn the CD?
Thanks !
Old 11-13-2008, 03:07 PM   #8
sativen is an unknown quantity at this point
Two things:
1) What tags are you using ID3v1 or ID3v2.x? Some devices will only read ID3v1. Also, some programs, like iTunes, are sloppy about writing tags (or so I've heard, I don't use it).
2) You said that you verified tags. Did you verify before and after the burn (i.e. the files on the hard drive and the files directly from the CD). Just a thought.
sativen is offline   Reply With Quote
Old 11-13-2008, 03:36 PM   #9
1) the first time, I've used Winamp tagger but didn't work. Id3v1 and Id3v2 where there. The tag where still theyre on the CD.
2) After this I have tested "Mp3Tag v2.4.1" and rewrite all Id3va and Id3v2 tag. still don't work. Tag are ont the CD after I have burned it with Nero.
Tags
9835, alpine, id3, mp3, tag
Alpine Head Unit From US FM to Europen FM davaid Car Audio 2 09-05-2007 04:18 PM
portable mp3 player w/o using head unit dirty9311 Car Audio 1 04-27-2007 09:23 PM
MP3 head unit issue - ALPINE DVA-9861 disker Car Audio 5 02-05-2007 06:32 PM
CarPC radio reception: PC tuner or head unit? xraycat Car Audio 1 01-18-2007 07:57 PM
car head unit BoneMan General Hardware Discussion 1 07-29-1999 10:30 PM
