Old 11-15-2008, 09:59 PM   #1
mnetwork is on a distinguished road
Thumbs up Eliminating Buzzing From CarPC/AC Inverter
I have a cheap 400w AC inverter powering my CarPC setup. I have always had problems with buzzing since I switched to this inverter. I recently changed my head unit and then the buzzing increased. I tried everything.. moving wires around, checking grounds, and even tried ground loop isolators. The ground loop isolator helped somewhat, but nothing acceptable. I finally tried grounding the case of the computer's power supply directly to the car with a foot of wire. This totally took ALL buzzing and noise away immediately. I have never had crisp and clean sound like this before. I am just putting it out there for anyone else having these issues.
mnetwork is offline   Reply With Quote
Advertisement Sponsored links
Old 11-16-2008, 07:34 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
This is one reason that inverters suck.
I would also guess that your PC PSU is a cheap no-name brand, as well.
Why is this in the FAQ section?
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 11-16-2008, 01:27 PM   #3
My PSU is an IBM PSU and grounding the computer to the car totally took away all buzzing and noise. I get to use a cheap inverter without any of the consequences.
Old 11-17-2008, 10:53 AM   #4
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
Cause I haven't moved it yet.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Inverter now cauzing buzzing noise?? wtf? Yellow-Snow General MP3Car Discussion 3 11-11-2006 02:13 AM
Fixed My Buzzing with AC Inverter jjcuff1 General Hardware Discussion 13 02-02-2005 10:15 PM
Help Eliminating Inverter Noise - Options prospero General Hardware Discussion 4 04-21-2004 02:37 PM
inverter buzzing brandondere General Hardware Discussion 4 06-09-2001 06:06 PM
eliminating inverter Smacker Power Supplies 6 04-12-2001 01:58 PM
