Quote: Originally Posted by
joey7415963
Hi,
I'm extremely new to this but from what i gather you are questioning how to get surround sound through your car speakers.
Firstly you need a surround sound card on your PC, you then attach the individual channel outputs to an amp and then to your speakers but from what I've read you will have to keep the gain low else you will blow the speakers.
Like I said I am new to this so if this doesn't help I am sorry.
Yeah that would work.
If each channel has its own dedicated audio cable (6 channels of RCA cables) you will have no problem doing this.
Convert the "Front" audio jack to RCA and plug that into your front amp.
Convert the "Rear" audio jack to RCA and plug that into your rear amp. Convert the "Center" audio jack to RCA and plug that into your center amp.
Convert the "Subwoofer" audio jack to RCA and plug that into your sub amp.
If you had a 5 channel amp and sub amp you would be set.
Center and Subwoofer are each mono jacks, so that is 6 channels total.
But, do you really have a center speaker in your car? If not its going to sound weird. Volume will have to be controlled on the computer and gain knobs adjusted perfectly on each amp.
This is a great idea. i hate when people shoot down good ideas.
