What are they? Is that 4kw RMS or max? I'm guessing "max", which is a term that means ZERO!
Also, how are the subs wired? If you have two subs, both SVC, and both 4ohm, and wired together, you either have a 2ohm load or an 8ohm load... If they're at 4ohm, that means they're on separate channels. Going with a 2 ohm load on a decent-quality class D mono sub amp is going to be your best bet. As to what size you'll need, it's gonna require knowing what you have... Which is still up in the air.
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
