Old 11-19-2008, 09:53 PM   #1
hmonay is an unknown quantity at this point
connection from car pc to amp
Does anyone know how to tap the sub output?
I read the FAQ
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=7
but the diagram only shows the sub with one RCA output
would the be fine when connecting to an amp which has the R and L
rca inputs????
hmonay is offline   Reply With Quote
Old 11-20-2008, 07:13 PM   #2
kross is an unknown quantity at this point
A sub amp just combines the incoming L and R signals to a mono signal. The sub output on the sound card has already been combined for you. I suppose you could just plug it in to either the L or R input on the amp, but I'm worried that leaving the other input floating would introduce noise. So you could either use a splitter, and feed both inputs, or get one of those little plugs that shorts the center pin to ground, and plug that into the unused input.
kross is offline   Reply With Quote
what type of amp for my car pc.. tanners Car Audio 3 04-18-2007 02:53 PM
Car PC & Bose/Philips CCR800 Aux input Gamer64 Car Audio 1 01-25-2007 04:13 PM
