Old 11-28-2008, 09:54 PM   #1
Bmrbch's Avatar
Bmrbch is an unknown quantity at this point
02 Jeep Grand Cherokee install
I am installing a Car Computer into an 02 Jeep Grand Cherokee. It has Infinity amp and speakers. I do not want to rewire the amp/speakers combo but just want to replace the head unit and plug the computer out line into the existing amp. I have been told I need an adapter (high to low?). Is this true and where would I find one of these? My current understanding is that I take the speaker out from the computer, convert it high to low, split the signal (front / back speaker lines) and put it into the amp. Or do I need a more robust adapter? Any help would be appriciated.
-Brian
Bmrbch is offline   Reply With Quote
Old 12-05-2008, 01:18 AM   #2
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
I used to have this car..... I never put a PC in it though. Just buy the adapter for the connections were the headunit should go. Do this so you dont have to cut off the original factory plug piece. It will get very confusing if you do. Amoung the wires on the wiring kit you buy will be a wire to power on the amp. You can just connect that to a serial port and use something like amp control to power it on when you turn on your pc. All the rest of the set up should be just like normal. I would try to go to the jeep forums and ask in there, they will know more. http://www.jeepforum.com/forum/
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 12-14-2008, 10:23 PM   #3
Bmrbch's Avatar
To anyone with the same question... 02 Jeep Grand Cherokee with infinity gold system has no problem taking the output from the computer. I got a OEM-1CHR2 adapter so that I can get front / back fade, but it's not required. Oh, and a good chassis ground will take out most if not all of the ground loop. Also got a ground loop isolator from wally-world that crushed that problem.
02 Suburban Install Advise TheFriedBoot Newbie 0 05-22-2008 12:23 AM
Need ideas on my 06 jeep cherokee install jb3600 Fabrication 0 10-15-2006 11:34 PM
jeep grand cherokee install jackjohnson24 Newbie 1 01-12-2005 02:53 PM
Jeep LCD install kit? Tommyboy LCD/Display 1 08-07-2002 07:47 AM
