Old 12-08-2008, 01:54 PM   #1
prod is an unknown quantity at this point
Speaker level input + RCA output?
I am wiring 2 amps, a 4channel for the doors and a monoblock for a sub. I am using the factory head unit with no RCA ouputs.
Can I use the 4channel amp speaker level inputs and connect one of the RCA outputs to the RCA input of the mono amp? In other words, does the amp convert the high level input signal to line level and send it to the RCA outs?
prod is offline   Reply With Quote
Old 12-08-2008, 04:44 PM   #2
Woofnstuff's Avatar
Woofnstuff is an unknown quantity at this point
no, is the short answer
use one of these speaker level to line level adapters
http://www.davidnavone.com/cart.asp?24&cat=7
Woofnstuff is offline   Reply With Quote
Old 12-08-2008, 08:31 PM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
There are also equalizers that accept speaker-level input and output line-level for an amp or amps.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 12-10-2008, 05:32 AM   #4
AudioXtreme is an unknown quantity at this point
Not unless your four channel amp has RCA's that are labled as outputs. Usually it will say Sub Out or Thru. Without knowing the amps that you are using it's hard to say what is possible with them except to take Woofnstuff's advice and get a line level adapter. Some amps have built in crossovers that will take your incoming signal whether it comes from the high level or signal level inputs and sends the highs on to the amp and the lows out another set of RCA's that you can connect to your sub amp. But just connecting from one amps RCA inputs to the other amps input could be trouble depending on how the signal is handled after it goes into the one amp.
AudioXtreme is offline   Reply With Quote
Speaker wire to RCA cable to amp klutes Newbie 4 08-16-2008 10:07 PM
hooking up subs threw high level input insted of rca HELP ineedhelp101 Car Audio 4 05-05-2008 11:26 AM
The RCA or S-Video output of JETWAY mobos is not acceptable? derekc LCD/Display 3 10-18-2007 04:43 PM
PSone LCD: Possible to switch between VGA input and RCA input? mattress LCD/Display 10 06-07-2006 10:13 AM
can I use an amplifier for rca input?? sheriff General Hardware Discussion 1 03-23-2001 09:03 AM
