Amp trouble. Please help
I just installed a new system in my car. Head unit, speakers, amp, sub, the whole shabang. I got the infinity 5 channel 5350a. I had it before but it got ripped off in my old car. I liked it so I got another. sooo..... we got everything installed and the all the wires ran. We started it up and the music started playing. It was very clear and completely free of any hissing, then my cousin folded the seat down.... when he did this he disconnected and broke the metal piece on the ground. It went into protect mode or whatever that is and we turned it off. Ever since that the speakers have been making these terrible sounds. We're pretty sure its the amp.We got a new terminal for the ground and sanded the ground spot. Didn't help. Then we started messing with the rca's and we found that if you disconnected either the right or left rca and just touched it to the input jack, but not actually put it in, a considerable amount of the hissing went away, but the second we plugged it back in, HISSSSSSS. It doesn't make any sense. My cousin also tried setting the ground not while the car was on, but while the battery was still connected. I don't know if that makes a difference. he thinks the amp is messed up. No fuses blew or anything like that. Replacing the amp if need be isn't the issue, but does this sound like the sort of thing that could do this to an amp? I'd really appreciate any help, as I'd had a very disappointing two days.
Also if it matters the amp is 50wx4 and 150x1 rms. I had a 4 guage kit that came with a fuse block with a 100a fuse, but it was messed up so we got one real quick at best buy. Its a rockford with a 60a fuse but I doubt that would have anything to do with it, as I'm not running that much power anyway
