That wire may be a very low current wire. I'm gonna assume that the factory radio used this wire to determine whether the ignition is on or off. So I'm guessing (I've never heard of your car) that wire is capable of just a few milli-amps. If this is the case, can it turn a relay on and off?
At this point I don't think its the radio. If you hook the 0/12-volt (Ignition) wire to the radio and it drops to 0-volt, then something before the radio is eating up the voltage.
I wonder if this wire can turn on a relay? Typically most relay coils work around 200 milli-amps or less.
