12-23-2008, 09:53 PM
#1
93 lexus es300 aftermarket radio install i need help!!! experts help
hi everyone im a newbie and need some help.i just recently bought a 93 lexus es300 without a radio which i wasnt happy about but i figured hey ill buy a radio and throw it in.so i bought a nice panasonic cd mp3 player.the guy i bought the car from had his own system in it amps subs but took it all out so i have an empty dash.i know my lexus had factory amps and stuff like that but im pretty sure he either disconnected that or removed it completely.now how much is this going to affect me when i attempt to install my new head unit.will a simple wire harness for a lexus es300 plug and play right in the factory wires as it should.or will it be a big pain because the amp isnt there anymore.please help guys i needall the help i can get right now ive been driving the car for 2 weeks with no radio and im going nuts please help!!!
12-24-2008, 11:55 AM
#2
It all depends on what the previous owner did to the car. If you are lucky, he used the harness and just ran wires to the dash from his amps. He may have ran new wires straight to the amps, which would complicate things for you. Your head unit should have an internal amp, and you could connect the speakers directly to the head unit. If the previous owner ran wires to wherever the amps were, it may be easier to just buy an amp and run some RCA cables from the head unit.
I hope that made sense and will help you. Maybe if you described what wires you have in the dash, we could help a little more. Pictures also might help.
12-24-2008, 12:48 PM
#3
hi scate thanx for taking the time to help.the only wiring i have in my dash of my 93 es300 is the factory wiring which is 2 white wire harnesses one for the radio ,one for my factory cd changer in the trunk (which i know is useless now) my metal antenna wire and also some metal prod like wire that was taped up so it didnt touch or rub on anything.the guy i bought the car from had some big subs and amps in the trunk and i checked today and he taped off (bypassed i think?)the factory amp under the passenger seat.so i know its not there anymore any and all help i really appreciate i need music in my car im going crazy!!
12-24-2008, 01:13 PM
#5
I had the same problem with my 05 but fortunately they make dash kits and harnesses for them, you should be able to find the kits for your model at the stereo shops or on-line. I was trying to do my 05 but momma wasn't having it. Took too long installing the computer in the truck.
If you cant DODGE em, RAM em.
12-24-2008, 03:41 PM
#6
i dont have the factory amp anymore.it was completey removed and the wires were taped up.i dont really want to purchase another one and spend more money unless i have to.please let me know whats the easiest way of getting my radio up and running thank you
12-24-2008, 03:49 PM
#7
When you say "taped off", do you mean these wires are now disconnected? or are they connected to wires that run to the trunk?
I think you could run speaker wire from the dash to these "taped off" wires, and then connect them to the speaker output on your head unit. That should get it working.
12-24-2008, 03:51 PM
#8
Well Pete,
I am no expert but it seems your only other option is to hard wire your stuff into the speaker system. Your HU into an after market amp then into the speakers, that is if you want an amp although I recommend it.
12-24-2008, 03:54 PM
#9
You shouldn't need an amp. Your head unit has one.
12-24-2008, 06:21 PM
#10
yes scate my panasonic head unit im sure has an internal amp its 50wx4 so what should i do?just buy a harness and wire everything up normally?again thank you for all your time i really appreciate it
12-25-2008, 12:19 PM
#11
so scate so what should i do?buy the harness you showed me and just plug the rca plugs that come off it into the rear of my head unit causei know this panasonic head unit has an internal amp its 50wx4
12-26-2008, 12:35 AM
#12
Sorry it took me a little while to respond.
You need that wiring kit and probably a kit to mount it in your dash. Because the factory amp is gone, you can't use the RCA cables from the kit. You will need to run speaker wire from the dash to wherever the factory amp was. Those wires will connect to the speaker outputs. You will need 4 sets of speaker wire.
Did I word that confusing? Let me know if it doesn't make sense.
12-26-2008, 12:51 AM
#13
I don't know about you, but visuals always help me.
You want to splice your new wires with the existing ones where the factory amp used to be. Front Left to Front Left, Front right to front right, ...
12-26-2008, 10:46 AM
#14
ok that helps for sure.my factory amp was under my passenger seat which i have to remove ,i am so excited about that haha,now when i run the speaker wire from the dash to the existing wire where the factory amp was.what wires in my dash am i splicing into?that kit only has 5 wires to connect which i believe is acc,power,ground,remote.so what wires in my dash am i splicing into for my speaker output?and are the wires under the seats going to be red and blue?like your diagram or what am i looking for. thank you again scate your a friggen god-send.
Reason: misspelled
| Thread Tools |
| Display Modes |
Linear Mode
