Old 12-30-2008, 09:16 PM   #1
Hessian's Avatar
Hessian is an unknown quantity at this point
Hot Audio DACs
Has anyone tried these DACs?
http://www.hotaudio.com/zen-cart/ind...4d86944972bc45
There are a couple different variations. I'm looking for something to feed my 3sixty.2 processor. The MARK IV looks like a good choice at $140.
2007 Mustang - RockCar Front End
Hessian is offline   Reply With Quote
Old 01-03-2009, 11:19 AM   #2
Hessian's Avatar
Mark IV Specs
The DAC on the Mark IV is a Burr Brown PCM2705 (USB and DAC). I'm not sure of the opamp.
The Hippo HIfi Bloat for comparison uses the PCM2707 chip for USB combined with the PCM1794 DAC, but for $229.
I'm not sure how much of a difference this will make in sound quality out of the USB port which is 16bit. Both seem to use USB 1.1 from what I can tell.
I'm new to DAC technology. So I'm learning as I go. Dave at HotAudio has been great in answering my questions.
Other Mark IV Specs :
THD+N when driving a 16-W load is 0.03% at 1 kHz
THD+N when driving a 32-W load is 0.02% at 1 kHz
THD+N when driving a 10-kW loads is 0.005% at 1 kHz
Thermal and Short-Circuit Protection
Sampling Rate: 32, 44.1, 48 kHz
Has 3.5mm Stereo Headphone Output Jack on front
Left and Right Gold plated RCA line level outputs to drive power amplifiers, receivers.
Dimensions: 65mm by 65mm by 30mm ( 2.5 inches by 2.5 inches by 1 inch )
Weight: Approximately 100 grams
Extremely Low Jitter
USB 1.1
Chips:
http://www.digchip.com/datasheets/pa...77/PCM2705.php
http://www.digchip.com/datasheets/pa...77/PCM1798.php
http://www.digchip.com/datasheets/do...number=PCM2707
Old 01-05-2009, 09:54 AM   #3
Hessian's Avatar
I've been reading this thread on the Hot Audio DACs.
http://www.head-fi.org/forums/f5/hot...s-amps-242880/
audio over USB v. optical RedGTiVR6 High End Solutions 358 12-29-2007 08:51 AM
Audio Interrupt "Black Box" for Stock Head Unit jmciver Hardware Development 11 10-11-2007 03:15 PM
Outputting from car audio head unit to home theater receiver mach5 General MP3Car Discussion 9 05-31-2007 12:20 PM
some audio questions for my setup PatrickB General MP3Car Discussion 12 05-11-2005 08:37 AM
XMDirect Digital Audio Output ? Retsaoc General Hardware Discussion 13 10-11-2004 09:10 PM
