Strapping Amps + Sub Wiring Question
I have two kenwood excelon X1R mono-block amps. They are rated at 1200w rms at 2ohms and 600w rms at 4ohms. I am having difficulty finding a 2ohm woofer that is able to run at 1200w rms. However, both the Alpine X-series and MTX 9500 are rated at 1000w rms and 3000 peak. My problem is, the Alpine X-Series and MTX 9500's only come in a 4 ohm woofer. How would I be able to wire my amps in order to power 2 4ohm woofers as 2 2ohm woofers?
My initial thought would be to run each amp in a parallel circuit. One amp being attached to one voice coil and the other amp being attached to the other voice coil.
I am open to any and all suggestions. I have been working on figuring this out for days. Any help would be appreciated.
