Old 02-11-2009, 09:30 PM   #1
stratosigma is an unknown quantity at this point
Question Audio advisor suggests using PC as head unit is horrible...
I wasn't sure where to post this, but since it's directly related to the audio portion of the pie, I figured this was best.
I recently spoke to a customer service rep at an audio products company, (I'll leave them unnamed, don't want to unnecessarily call anyone out) and informed them of my plan to get rid of my OEM head unit and replace it with a PC, which would then be amped to the speakers.
They advised me this was not a good idea and that the sound quality from PC to amp is horrible. I've seen people on here do it, so I'd like to know what the results are in the real world and suggestions on getting the good sound
stratosigma is offline   Reply With Quote
Advertisement Sponsored links
Old 02-11-2009, 09:35 PM   #2
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
There are a great many things that contribute to the quality of the audio when a computer is involved. The quality of PC power, shielding on cables, quality of the mp3/audio that is being played, quality of the sound driver in the PC, quality of the amplifier....
Done wrong, yes it can be worse. Done right, it can possibly be better than a stock headunit (possibly).
My guess is the audio adviser thinks he won't make any money off you if you put a PC in your car :P
malcom2073 is offline   Reply With Quote
Old 02-11-2009, 09:42 PM   #3
I thought about that too, after telling him I was OK with my stock system but a little upgrade couldn't hurt he suggested keeping my head unit and installing 4 Boston Acoustics S85s, totaling $240.
So, I'm a little dubious of the advice, rightfully so I believe. Earlier in the day I had an email chat with a different advisor where I mentioned ditching the head unit but keeping stock speakers and they gave me a list of stuff:
Stereo Mini to RCA Adapter, Kenwood KAC 6404 Amp, Amp wiring kit, 4 RCA cables from PC to amp, Speaker wire to go from amp to stock speakers. This seemed to be a much more thought out response, and afterwards I figured maybe I should at least upgrade the front speakers.
If anyone else is interested in giving advice or critiquing the advice I received, the PC I'm building is using the D945GCLF2 motherboard, so the 5.1 sound on there is what is available to me.
Old 02-11-2009, 09:50 PM   #4
pcpete's Avatar
pcpete is on a distinguished road
For good SQ i recommend, NO INVERTERS, have pc as close to amp as possible, preferably do not use integrated audio, and lastly ...overground the ***t out of everything!!
pcpete is offline   Reply With Quote
Old 02-11-2009, 10:41 PM   #5
bratnetwork's Avatar
bratnetwork is an unknown quantity at this point
you can get very good sound quality out of a PC if you use a digital output into a good sound processor then into amps, but this method can be very pricey. A high end sound card will give you a good sound, or even a decent integrated can give pretty good sound if you use a hardware processor / eq to tune it right. If you're not looking for audiophile sound then just using the integrated sound into a some amps and some tuning in software EQs will produce a better sound than most OEM sound systems
bratnetwork is offline   Reply With Quote
Old 02-11-2009, 11:01 PM   #6
That's kind of what I thought. There's no way people are doing this and living with crappy sound. I'm not an audiophile, most of my music is on my iPhone so it's compressed anyway. I'm happy with the sound from my stock stereo, I just figured if I'm gunna ditch the head unit, I might as well upgrade just a little.
I mean using that Kenwood amp the other advisor suggested and upgrading the speakers will probably result in audio that is superior to my stock unit, wouldn't you think?
Old 02-12-2009, 12:26 AM   #7
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
For decent quality sound, get a sound card.
RedGTIvr6 wins SQ competitions with her computer based sound system, so it can be done.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 02-12-2009, 04:03 PM   #8
CwF
CwF is an unknown quantity at this point
Why no Inverters? Maybe not certain types/kinds?
06 Silverado LBZ wants onboard everything...
CwF is offline   Reply With Quote
Old 02-12-2009, 04:11 PM   #9
pcpete's Avatar
I'm not an expert, but the sine waves of the current created are square like, not smooth.
This can induce really bad noise and whine into the audio. I have used one with a laptop, and the noise was unbearable.
The cost of a really good one plus the cost of an atx psu will probably be double the cost of a decent dc-dc regulator/psu.
With the dc dc regulator/psu you also get pc startup and shutdown control. Mine can also delay the power up of my amps to protect my speakers from the pc startup 'pop' .....
Old 02-12-2009, 04:13 PM   #10
PaulF's Avatar
PaulF is on a distinguished road
Most inverters use a modified sine wave which causes a buzz in the speakers. There are expensive pure sine wave inverters which would probably be okay to use but you lose efficiency and theres no guarantees that it will be perfect. It's pointless to go from DC to AC to DC again which is essentially what you're doing when hooking up a computer through one.
I would advise you to use some form of a hardware pre-amp. In my car if I plug my mp3 player directly into my amplifiers, it sounds okay, but if I plug it into my head unit and plug my head unit into my amps, it sounds much better as the head unit is tweaked to provide the best sound for a car environment.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Old 02-12-2009, 04:25 PM   #11
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
I have one question.
My Commell LS-373 have Realtek ALC888 onboard sound card. If someone compare this Realtek ALC888 Sound card with some other USB card? I will use digital out(optical) connected to processor(Audison BIT ONE)... So is in optical out any diference?
_Dejan_ is offline   Reply With Quote
Old 02-12-2009, 04:58 PM   #12
Correct me if I'm wrong, isn't a preamp to amp low level signals to line level? The PC is already at line level? Is a preamp really necessary?
Old 02-12-2009, 05:27 PM   #13
Bugbyte's Avatar
Right. PC is at line level. If your sound card provides equalizer (which it ought to), you will probably be okay.
Want to:
-Where is the iBug?
Old 02-12-2009, 05:50 PM   #14
PaulF's Avatar
Yeah Bugbyte is right, if you have an equalizer to work with you can probably make it sound pretty good. Give it a shot without a preamp or head unit and you can always put one in at a later point. Even without tweaking, it will probably sound okay.
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 02-12-2009, 05:54 PM   #15
rijndael's Avatar
rijndael is an unknown quantity at this point
im probably jumping in here a little late, and bugbyte is right, no preamp is needed.
one thing i would look at to help you make an informed decision is "The Art of Bulding a Computer Transport"....google it. I know you arent into the whole audiophile thing, but it will give you an idea as to how far PC's have come compared to high-end hi-fi equipment (as well as maybe even help you decide on certain components and how to keep EMI at a minimum). EMI is electromagnetic interference if you didnt already know that....but im sure you did.
anyways...if you are worried about the connections to your amplifier (as that sales-rep supposedly said it sounds like crap), you can just get a quality y-splitter 3.5mm jack to RCA (usually around 24 bucks for 3 feet..ill do a search for one and post it for you here...i use one from Stinger, and it definately sounds better than monster cable did) and keep it clear of all power cables/grounding cables and your VGA cable (energy bleed which causes interference in your cable).
someone else probably responded since bug's last response, so im gonna go search for a y-splitter that you wont have to worry about...if you do end up going this route
Trouble deciding on car speakers? Clicky Clicky
My Myspace page (view my pics for carputer worklog...needs updated)
Speakers: DLS Ultimate Iridium 6.3 Link
Subwoofer: removed
Amplifier#1 (Front Stage): DLS Ultimate A4
Amplifier#2 (Sub) removed
rijndael is offline   Reply With Quote
CarPC radio reception: PC tuner or head unit? xraycat Car Audio 1 01-18-2007 07:57 PM
Easy head unit question, and PC to amp question. dudah85 General Hardware Discussion 3 09-09-2001 04:57 PM
