Old 04-22-2009, 11:54 AM   #1
TeamRSX's Avatar
TeamRSX is an unknown quantity at this point
Question Volume Amp Control Question
Hello,
I am getting a thump from my amp on startup and want to use the Volume Amp Control program which most ppl have success with, but want to make sure i have this correct.
Currently, i have 2 amps, dsatx and hd radio remote wire going to a 30a automative relay which then ties into a switch and from the switch to my igniton to turn on the devices.
My question is do i just connect pin 4 (DTR) from my serial to my amp remote wire? even though all my remote lines are going to my relay? If i attach a wire from the serial to only my acc for my amps will this only delay my amps?
I don't want this to effect my computer or hd radio. Since all my accessories are connected to my relay. I am pretty sure i can do it this way, but jsut want to double check as i have been wrong several times on occassion before.
I know this doesn't work for all amps and some ppl use a resistor, but want to try without a resistor first to see if it works.
Cheers,
Blair
TeamRSX is offline   Reply With Quote
Advertisement Sponsored links
5.1 Amplifiers with Optical inputs RedGTiVR6 Car Audio FAQ 108 11-02-2009 09:47 PM
Volume control on PC or headunit? efun Car Audio 10 01-15-2009 10:48 PM
Enhanced Volume Control XxAndyxX Software & Software Development 15 06-12-2007 09:25 PM
M-Audio with ASIO volume control mkysimes2 Road Runner 6 04-17-2007 12:25 AM
NooB Question: Orion amp paired w/ L7's gab5 Car Audio 12 02-03-2007 06:22 AM
