Quote: Originally Posted by
bes51659
You have a ground loop with the audio and the USB cable.
1) Are the analogue extension and the USB cable drawn the same way from the boot to the LCD panel?
You could have a loop sensitive to magnetic noice that is proportional to area between the two wires. If possible, twin them.
2) You could break up ground loop in audio with standard component, or use a wireless USB hub.
3) You can cut the red and the black wire in the USB cable and source the LCD panel with 5V separately from dash.
Option 3 is quite good, if you do not want to use a wireless usb hub.
Best way to do it is to cut it aprox 1m from the end, and there re-solder white and green back to the usb that where cut off, and then red to a 5v source (while the ignition is on) and black to ground.
5V can be ashieved with a resistor. (usually a 350 ohm ressistor).
NOTE:
Use V = I * R to determine the ressistor. (And keep in mind that there's a different voltage in your car when engine runs, and when it's off, and check up on how many milliampere the USB hub at).
