I am installing this on a 2004 Subaru WRX. I have a Kenwood KAC-628 that I was hoping I would be able to use for my carputer 2 channel audio power. I am pretty sure that my stock speakers run at 4 ohms and are connected in parallel from the stock HU wiring harness. Can I just connect from the amp to the stock HU harness, this way not having to reroute wiring to speakers in doors?
Here is the info sheet for the amp:
http://inform3.kenwoodusa.com/manuals/kac528.pdf
It looks as if I'm connecting the (4) 4 ohm speakers to the amp in parallel, it will run at 1 ohm, which I don't think this amp will do. Or does it just treat it as (2) 4 ohm speakers running at 2 ohm, which I'm pretty sure the amp will do. Any advice is much appreciated.
Also, will I be okay with running 18 AWG speaker wire from amp to stock HU harness?
