Old 05-01-2009, 09:21 PM   #1
JSewell is an unknown quantity at this point
how much power
So i had a quick question about this setup
http://akamaipix.crutchfield.com/ca/...8-ohm_mono.jpg
Lets say the 8O speakers are about 300RMS and we have 3 of them
Lets add in a 900RMS Amplifier to power it all with this wiring configuration
Now my question to you is would these subs be seeing 900W or would i divide the RMS of the amplifier by the number of subs, giving my 300W each
JSewell is offline   Reply With Quote
Old 05-02-2009, 12:17 PM   #2
deanb2's Avatar
deanb2 is an unknown quantity at this point
What that diagram is telling you is that 3 8 ohm speakers wired in parallel will present a 2.7 ohm load to the amp.
You don't say at what ohm level the amp is rated at 900 watts.
If it is 4 ohms, then the output power will probably be somewhat higher than 900 watts, closer to the 2 ohm rating of the amp.
If you wired the speakers in series, then the amp would see a 24 ohm load.
Dean
deanb2 is offline   Reply With Quote
Old 05-02-2009, 04:10 PM   #3
thewizard's Avatar
thewizard is on a distinguished road
If the amp is rated at 900WRMS at 2ohms, then yes the subs would see 300 watts each. If your amp rating is at 4ohms, then it would likely make about 1200 watts rms at 2ohms, provided that the amp in question is in fact 2ohm stable. Then your subs would see about 400 watts each. If it was me I would never purchase subs with 8ohm coils for a car system. Get 4ohm coils if they are single voice coil, or 2 ohm if they are dual voice coil. This will provide the best possible configuration for most applications. As for bass amps, look for an amp that is stable at 1ohm, this will provide a sturdy foundation for any application.
thewizard is offline   Reply With Quote
USB Syncroized 5V@8A power supply POL. Now Taking Orders!!! Beehphy User Innovations 110 06-23-2009 04:22 PM
Hardware Review: M3-ATX Power Suply Bimmerstyle The Review Palace 8 03-05-2008 06:57 PM
fried my carnetix power supply? mustanglou Power Supplies 2 11-10-2007 12:34 PM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 01:08 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
