Old 05-03-2009, 11:31 AM   #1
king9899 is an unknown quantity at this point
Amps????????
hi, i have 2 1300w sony xplod subs in my trunk. I am attempting to hook them up and i am wondering what kind of amp i should use. I do not want to fool with the speakers in my doors i just want the extra power in the trunk. I have a sony xpold deck and i was wondering also how i wire that to the amp and subs.
king9899 is offline   Reply With Quote
Old 05-03-2009, 11:53 AM   #2
D4V3 is an unknown quantity at this point
Your deck might have a separate sub out, go and check.
Take a Sony Xplod (or any other) amp to fire the subs.
D4V3 is offline   Reply With Quote
Old 05-03-2009, 12:20 PM   #3
Injector's Avatar
Injector is on a distinguished road
is 1300W the rms rating or the max?
Injector is offline   Reply With Quote
Old 05-03-2009, 12:58 PM   #4
funkyphil's Avatar
funkyphil is an unknown quantity at this point
if the subs are rated at 1300 rms this means the subs can handle the 1300 watts all the time. Now if it is 1300 max, this means when sony tested the subs, they maxed out the subs just before they blew up and what number it maxed out at is your max. in this case would be 1300 watts. But if you read the manual you'll probably find that your subs might be rated at an rms of say 300 or 400 watts. With this all said, you are to get an amp that can handle your rms rating, and if your speakers are rated at 300, then i would put say 250 watts to them or a bit more.
Now hooking them to your system, on the back of your deck you should have two possible three rca out puts. if you have three, one will be a sub out. this is the one I would use. run a longer rca cable from this out put and plug it in on the amps input. wire the amp as normal 8 gage wire from battery, 10 gage to a chassie ground, and a remote turn on from the radio or remote switch. if you only have two rca out puts. I would run the rca from the deck out of the rear rca cable.
This should do it, have fun and let us know if you need further help.
Phil
www.philscustomcomputers.com
funkyphil is offline   Reply With Quote
Old 05-03-2009, 06:30 PM   #5
so if i did not touch the speakers in my doors, and left them stock, but put 2 1300 w sony xplods in the trunk what kind of amp would i use? how many watts and how many channels.
Old 05-03-2009, 06:37 PM   #6
Injector's Avatar
you need to tell us the rms rating on your subs before we can tell you what kind of amp to use and whether or not to bridge the channels or not.
Old 05-03-2009, 06:40 PM   #7
it does not say that...all it says is 1300 max
Old 05-03-2009, 07:12 PM   #8
Virac is an unknown quantity at this point
What model sony is it then look it up online at crutchfield or sonys site
Virac is offline   Reply With Quote
Old 05-03-2009, 07:52 PM   #9
the rms is 380 on the subs.
Old 05-03-2009, 09:11 PM   #10
Injector's Avatar
you can buy a 760W 2 channel amp, and bridge the subs, what i mean is:
+ from channel 1, - from channel 2
- from channel 2, + from channel 1
just make sure that the amp you buy can go to at least 2 ohms.
don't feed 1300W to the subs, after 380W the sound will just distort and sound like crap
Old 05-03-2009, 09:20 PM   #11
will this amp work for just the two 1300 watt subs? just take a look at it....
http://www.sonystyle.ca/commerce/ser...h=n32150n46280
Old 05-04-2009, 12:00 AM   #12
boomintrac's Avatar
boomintrac will become famous soon enoughboomintrac will become famous soon enough
OP-get a mono amp that puts out between 600-800 watts rms and you will be fine. I would recommend 1000 watts rms just for some overhead to prevent distortion from arising. Most distortion will be from under powering a speaker and over driving the amp to compensate by twisting the gain resulting in an in proper gain setting clipping the signal.
Aron
Zapco DSP-6
Zapco 500.1-Midbass-X2
Zapco 360.4-Midrange
Zapco 360.4-Tweeters
Zapco 500.1-Sub
boomintrac is offline   Reply With Quote
Old 05-04-2009, 01:58 PM   #13
Injector's Avatar
why do you need a 4 channel amp? and for the 5th time do not feed 1300w to your subs you might end up blowing them.
Old 05-04-2009, 05:18 PM   #14
but dont you only hook the subs up to one channel?...i was going to get a 4 channel amp in case i wanted to hook more speakers to it later to go in my doors. can that be done?
Old 05-04-2009, 10:39 PM   #15
Injector's Avatar
yea just make sure the amp you're going to buy a a built in crossover, you don't want to feed highs to your subs
What AMPS do you recommend? HiJackZX1 Car Audio 40 05-05-2009 04:36 PM
Relay Question mozee General Hardware Discussion 3 04-25-2007 11:20 PM
Amps, watts, volts and ohms dagnasty The FAQ Emporium 1 12-30-2005 12:35 PM
Audigy2 ZS to four amps... few questions. luckydevil General Hardware Discussion 1 10-08-2005 08:38 PM
will the opus 150 power my system? I have all the figures intense Power Supplies 13 04-15-2005 03:55 PM
