Old 05-09-2009, 02:18 AM   #1
jkklim is an unknown quantity at this point
Fuses blown, can someone tell me how I should wire this amp/sub combination?
http://cgi.ebay.com/ebaymotors/2-ALP...4506.m20.l1116
http://cgi.ebay.com/ebaymotors/ws/eB...2631&viewitem=
I just had a shop install the amp and the subs two days ago and it sounded really good. On the way home tonight the subs just stopped working and when I got home, I found out that 2 of the 3 25w fuses blew. Maybe I can rewire it somehow so that I won't have this problem.
jkklim is offline   Reply With Quote
Old 05-09-2009, 08:27 AM   #2
North of the land of Hey Huns
malcom2073's Avatar
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
Take it back to the shop. installing incorrectly should be covered under warranty.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 05-09-2009, 08:27 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Fuses are rated in amps, not in watts.
If the fuses are popping, then something isn't right.
If a shop installed it, take it back to that shop to make it right.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 05-09-2009, 09:20 AM   #4
Crinos is an unknown quantity at this point
Did you buy the amp there as well?
The amp can't draw more than aprox 1100 w at max load.
3 x 25 = 75A
75A * 14V = 1050 Watt
Allso, never ever bypass fuses... you can seriously damage electronical equipment, or even start a car fire... (And most likely, the insurance will not cover it).
Crinos is online now   Reply With Quote
In search of an ignition wire witten Power Supplies 16 07-27-2006 02:29 AM
blown fuses st_paul Newbie 4 05-16-2005 08:34 PM
where to buy wire to run from battery to inverter? hud Newbie 37 05-17-2004 08:01 PM
Looking forward to get the DC-DC PSU and now... cwho122 Newbie 11 03-09-2004 10:59 AM
ignition wire for opus psu liquid_smoke Power Supplies 3 09-09-2003 11:58 PM
