I believe the gnd pin on the M2-ATX Amp connection is just a ground point, it does not need to be connected.. My guess it is there for ease of driving a small relay from that header. Depending on your amp, you should be able to run the LEFT pin (which is the RMT signal form teh M2-ATX) to the remote wire of your amp. It will wait a sec or two after it has turned the computer on to turn the amp on, avoiding the pops.
EDIT: F1ip is right, I actually got my info from the manual, just reversed it in my messed up brain...
2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
