Old 05-26-2009, 10:04 PM   #1
spinerep622 is an unknown quantity at this point
Question Ipod to 5 channel amp, no head unit??
Hello,
I'm planning a system for a Polaris RZR side by side UTV. The sytem will consist of an Alpine PDX-5M amp, 2-6.5 component speakers, 2-6.5 coaxial speakers, and a 10" sub. I will be using an Ipod fed to the amp via a JL Audio CL-RLC 2 channel remote level line driver. My main question is, how do I take the 2 RCA's coming from the CL-RLC and split them to feed a 5 channel amp? Is this possible? I know there are Y splitters available, but are there any out there that turns 2 RCA's into 6? Help would be greatly appreciated!
Russ
spinerep622 is offline   Reply With Quote
Advertisement Sponsored links
Old 05-27-2009, 07:15 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
You need something that will take the simple stereo from the iPod and split it into 4 channels + sub for the amp.
Many equalizers do just this. I use an AudioControl Three.1 which is a great unit for the audio from my PC. It's pricey, but a damn fine unit.
There are other makes/models out there that can do the same thing.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 05-27-2009, 09:26 AM   #3
Crinos is an unknown quantity at this point
You would allso like to have a crossfilter of sorts... Either in the amp or before inside your splitter. (for letting the sub play the deep sounds, and not everything you put into it).
Crinos is offline   Reply With Quote
Old 05-27-2009, 11:10 AM   #4
soundman98's Avatar
soundman98 has a spectacular aura aboutsoundman98 has a spectacular aura aboutsoundman98 has a spectacular aura about
I am currently using a clarion 3 way active crossover. this allows for 2 inputs, and has 6 outputs, 2 high pass, and one low pass, all at 18 db/oct (much better filtering than most low/mid grade amps).
this is one of the better units that i have found for under $200. if you are interested in something above $200, audio control and alpine both make some great audio processors, that should also accept a stereo input and convert it to 5-6 channels.
http://www.sonicelectronix.com/item_...n+MCD-360.html
soundman98 is offline   Reply With Quote
Kenwood kna g510 installing into ALPINE head unit... BlueDream Car Audio 4 02-07-2009 01:17 AM
car audio amp stock head unit thebeebster Newbie 3 06-26-2006 10:26 PM
CD head unit remote amp turn-on - Can it be used to trigger standby? mach5 General Hardware Discussion 1 06-18-2006 05:45 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
