Old 05-30-2009, 10:08 PM   #1
MisterDeadeye is an unknown quantity at this point
Help With Camaro Sound System Planning
I've got a '96 Camaro RS that originally had a Bose system. I got the car used, with a pair of Alpine SPS-600s in the back. The front has 4" speakers right now, but I'm changing them to 6-1/2" as well as the back. I'm getting new speakers for the back, because while the Alpines aren't horrible, they sound distorted after a bit of loudness.
However, the distortion could also be from the stereo, correct? I've got an aftermarket Pioneer stereo, but it's pretty old. I'm not sure on the actual model of the stereo.
Anyway, I'm getting JL Audio C2-650X speakers for both the front and back if I can. I wanted to know if these are good speakers, and I also wanted to know if it was much better to have a multi-channel amp to power my four speakers. The amp I was planning on buying was the Hifonics ZXi 6410. The reason being that the speakers have a 60W RMS, 100W peak, and the Hifonics amp would be powering at 85W per channel. I wanted to get a mono channel amp for a sub.
Or, should I get a 5 channel amp for a sub?
This is my first post, so I'm not sure if I'm asking stupid questions.
MisterDeadeye is offline   Reply With Quote
Old 05-31-2009, 03:41 AM   #2
jake789's Avatar
jake789 is on a distinguished road
Instead of hifonics check out the AQ amps. They are similar but higher quality and better reputation. www.audioque.com
It would be much better to amp your speakers to get a louder/clearer sound from them. Its hard to ask which speakers sound better because everyone has their own opinions and favorite brands. I've never heard the JL's, but I'm sure they probably sound good. I would do your research and try to find reviews...
If I were you, this is what I would get.
6 1/2 component set for the front
6 1/2 full range speakers for the back
AQ490 4-channel amp
AQ1200 Mono sub amp
1 or 2 RE SE 12's or 10's (whatever fits)
If you upgrade everything above, then might as well get a new deck too.
Don't forget to do Big 3 wiring.
HTH
jake789 is offline   Reply With Quote
Tags
amplifier, camaro, jl audio
Monsoon Sound System weldonzk2008 Car Audio 7 09-14-2009 02:06 PM
2002 Volvo S60 Sound System PaulF Show off your project 3 01-05-2009 01:55 AM
Full Surround Sound pepsibobby Car Audio 17 02-12-2006 03:10 PM
Sound like a good system? 4.0 SOHC General Hardware Discussion 1 09-30-2005 03:17 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
