Old 06-04-2009, 06:38 PM   #1
Memphistwelves is an unknown quantity at this point
Unhappy Problem with SPL amp in protected mode
I recently hooked up an SPL 1800 watt 2ohm stable amp. I just hooked it up to 2 Memphis M3 Dual 2ohm VC subs. I hooked it up and ran them in series. The amp was pushing them great and it sounded perfect. On my way to work today everything just quit, i stopped to look at it and my amp was in protected mode. Everything to the amp is hooked up fine, no blown fuses, no wires crossed, I'm clueless.
Memphistwelves is offline   Reply With Quote
Advertisement Sponsored links
Old 06-08-2009, 08:22 PM   #2
thewizard's Avatar
thewizard is on a distinguished road
You would have to wire these subs in a series parallel configuration for this amp to remain stable. Wire two of the voice coils in series (one voice coil from each sub, then repeat the same with the remaining two voice coils) then connect both of the two series circuits in parallel at the amp. This will allow your amp to see a 2ohm final load. When connecting your series circuits be sure to connect + to - between the two coils so you end up having a positive and negative remaining for your amplifier connection.
thewizard is offline   Reply With Quote
Tags
amp, memphis, problem, protected, spl
Only problem left..... BMW E36 Amp. Hellmet Newbie 5 04-20-2008 09:49 AM
AMP Popping, Hissing, Shutting off...PLZ help?! Dougw133 Car Audio 8 12-10-2007 09:24 AM
2 to 1 amp problem lexdiamond20 Car Audio 2 07-02-2007 04:50 PM
Mustang amp problem Troteck Car Audio 6 05-14-2006 11:58 PM
bizzare amp problem vangore Car Audio 7 03-09-2006 09:58 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
