Old 06-08-2009, 01:13 PM   #1
81Z28 is an unknown quantity at this point
Car stereo without head unit
I'm looking to install a stereo in my Camaro.. it currently has no speakers or a cd player. Is it possible to just run an amp to a couple speakers and use an iPod as my cd player? Would i need an amp with an aux input? if so are these common?
Thanks!
81Z28 is offline   Reply With Quote
Old 06-11-2009, 04:27 PM   #2
soundman98's Avatar
soundman98 has a spectacular aura aboutsoundman98 has a spectacular aura aboutsoundman98 has a spectacular aura about
Thanks!
I am kind of confused what you are asking--- do you want a cd player and ipod connectivity, or just to use your ipod as the source?
if you want to use your ipod as the source, it is entirly possible:
currently, I am using my ipod as the source while i work on my car computer-- all that is required is a 1/8" stereo to rca cable that runs to the amp, and to hook the amp up to a switch to turn it off when your not in your car.
soundman98 is offline   Reply With Quote
Old 06-12-2009, 02:44 AM   #3
Sponge's Avatar
Sponge is on a distinguished road
Soundman's advice will work very well. I do the same when my computer is down.
Just annother option taken from this thread: http://www.mp3car.com/vbulletin/car-...tem-ideas.html
iPod->LOD cable->Volume knob->Amp RCA inputs
Sponge is offline   Reply With Quote
Old 06-12-2009, 03:48 AM   #4
Crinos is an unknown quantity at this point
You would need to tell the amp to turn on.. In other words, give it the 12v power-on (wake-up) signal.
This can be done many ways... either by flipping a 12v switch, or use relays and connected to ignition, so that the amp will go on when the car is running and stay on.
Crinos is offline   Reply With Quote
Old 06-12-2009, 06:57 AM   #5
smyles is an unknown quantity at this point
This might be a stupid statement (please correct me if it is) but, rather than rigging a switch or relays, could you not just wire the amp as normal and just use the 12V accessory line to the amp turn on terminal as a means to turn the amp on when the system is switched on. Is this not what the amp turn-on wire from head units do?
smyles is offline   Reply With Quote
Old 06-12-2009, 07:07 AM   #6
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
You are 100% correct.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-12-2009, 07:26 AM   #7
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Use a switch plus ign/acc just as a precaution. ACC->switch->Amp remote. This way it will always be off with the key off in case you forget so you don't drain the battery, and use the switch when the key is on and you want to plug in the ipod (or turn it on, etc.) so you don't pop the speakers.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
03Honda Accord-How Do I wire another head unit plus keep dual climate stock head unit Thormx037 Car Audio 6 05-11-2007 01:39 AM
Seat Ibiza Mk4 Alana Head Unit - need sound in! onlineamiga General Hardware Discussion 5 02-11-2007 06:02 AM
Taking internal amp out of head unit. stonestatue Car Audio 5 01-19-2007 02:28 PM
XM-Ready head unit software integration? TaZMaNiaK Software & Software Development 12 04-02-2005 06:23 PM
New Sony head unit - botched wiring... SamDude Car Audio 4 09-09-2004 05:21 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
