Old 06-09-2009, 04:23 PM   #1
WraithJ is an unknown quantity at this point
Alpine Stereo Faceplate Extension
Right guys odd question here, I remeber when i first came across this site 1-2 years ago there was a thread that had a guy who had made a cable that went between his headunit faceplate and the rest of it meaning he could have the headunit hidden but still control it. This is the sort of thing I really need to do in mine, I had a hunt round for the thread but couldnot find it anywhere. The head unit I have is an Alpine CDE-9881RB ipod ready headunit. Is there a cable out there already for this, has anyone made one, does anyone know what thread I am talking about?? I am loathesome to take the headunit apart as I like it and want it to stay working . If I need to I will. Does anyone have any advice?!
Thank you guys
WraithJ
WraithJ is offline   Reply With Quote
Old 06-09-2009, 06:47 PM   #2
jake789's Avatar
jake789 is on a distinguished road
I just did this in my truck and my Pioneer still works when extended 12ft. Your Alpine looks like it will work fine with extending it.
I'm using a 6ft vga cable that had 1 male end and 1 female end. So I just cut it in the middle and soldered the end wires to the deck, then I can just plug the connectors into each other to connect everything. I can also add extension vga cables easily if I wanted to run it farther.
I'm using a Pioneer 700bt.
I'll post some pics of the process later tonight.
jake789 is offline   Reply With Quote
Old 06-10-2009, 12:05 AM   #3
jake789's Avatar
Back of the faceplate
Inside deck
Switch needed to enable insert CD's, and antenna extended
Another inside of deck somewhat assembled
Back of faceplate. I used zipties on both sides of plastic to attempt to relieve any strain from the cables.
And it works!
Good luck, hope this helps.
Old 06-10-2009, 03:01 AM   #4
Sponge's Avatar
Sponge is on a distinguished road
Excellent work and soldiering skills!!
Sponge is offline   Reply With Quote
Old 06-11-2009, 06:07 AM   #5
that is cool, but i am just epic nervous about taking it apart, how precise a soldering iron do you need?
Old 06-11-2009, 06:15 AM   #6
Crinos is an unknown quantity at this point
If you do not have done some soldering before.. I would not reccomend this to be the first place to start...
It's easy to burn the PCB if you have a to hot solder.
Crinos is offline   Reply With Quote
Old 06-11-2009, 06:55 AM   #7
i have soldered before but not on such a 'important' peice of kit, im gonna do this at the weekend when I fit the new alarm sustem and car pc, I will post a walk through for thoose interested. Its gonna be a long weekend!
Old 06-12-2009, 12:13 AM   #8
jake789's Avatar
^ True, the one thing you need to be careful of is getting your pcb too hot. Do not use a 'screw driver end' type of tip for your iron, you'll have to get one that has a decent point.
Also, a good way to do it is first add some solder to the area before you wire to it. This will make it much easier. It literally only takes 1 second on each ball, then add some solder to each wire so that the wire is 'tinned'. Then you go back and reheat the solder pads and the wire together make a good connection.
Just take your time, and don't hesitate to ask questions, you should be fine. The solder joints on my deck were pretty easy and a novice should be able to do it as long as you have the right equipment.
headunit and screen?? also alpine type r sub? st_wanabe1 Car Audio 0 10-17-2008 04:48 PM
93 rx7 carputer help..alpine pxa-h701 users step in to... WickedRX7 Newbie 5 12-07-2005 07:50 AM
hacking a stereo faceplate? been done? telekineticfool Input Devices 11 08-12-2004 05:16 PM
Car Stereo Installation Video's for Sale johnram Classified Archive 2 09-05-2002 11:27 PM
New Faceplate for my Car Stereo? Falcon62Travis Off Topic 5 07-21-2002 04:21 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
