Old 06-10-2009, 01:30 AM   #1
mikey_350 is an unknown quantity at this point
Best subs for M1000 Amp
hello, i am new to this forum, and well car audio in general, been trying to learn. I have had a MRP-M1000 alphine amp for some months now, and i have been wanting to get some kicker subs for it. I want to go with L7's becuase they are newer and can handle more than the L5's but my amp wont push two 10" L7's will it?
Amp
1000W RMS x 1 2 ohms
600W RMS x1 4 ohms
i do plan on getting another alphine amp just like the one i have but, should i go with 2 ohm subs? or 4 ohm subs? and will it be able to run okay til i get my other amp?
subs
2 ohm
http://www.sonicelectronix.com/item_...ded+Combo.html
4 ohm
am i on the right track? or what should i do sub woofer wise, and remember i plan on getting another amp.... i understand its not good to underpower anything
thanks, Mike
mikey_350 is offline   Reply With Quote
Old 06-10-2009, 02:04 PM   #2
Sponge's Avatar
Sponge is on a distinguished road
Welcome Mike, yes, you are on the right track.
A 1000w amp and a pair of ported L7s can get pretty damn loud. I would recommend trying the set up with one amp first before you go spending a few hundred more on another amp... that you might not even need!
However, that poses a problem... if you choose to use a single amp you would want the dual 2ohm version and if you decide to run two amps, you would be better off with the dual 4ohm version. Read this to get a better understanding: http://mobile.jlaudio.com/support_pages.php?page_id=161. This is all in an effort to present a 2ohm load to your amp.
$650 is a large budget for subs, you can find some pretty nice equipment in that price range so shop around a bit more, talk to some people, listen to some systems and hop on some car audio forums. FYI: Kicker L7s and a box can be found on craigslist for pretty cheap.
Now go build a CarPC!
Sponge is offline   Reply With Quote
Old 06-10-2009, 02:45 PM   #3
nobb will become famous soon enoughnobb will become famous soon enough
The Alpine Type R series of subs are also very popular. Two of the 4 ohm ones in parallel would make use of the 1000 watts perfectly.
nobb is offline   Reply With Quote
Amp Wont Push Subs AltimateX Car Audio 1 06-29-2008 01:27 PM
orion subs and amp bwheat7 Car Audio 1 05-28-2008 08:06 PM
Amp running hot...?? Emerica2843 Car Audio 6 01-29-2006 08:29 PM
Help hooking up subs and amp? Need advice... jedi7001 Car Audio 6 05-17-2005 02:28 AM
Need to confirm my wiring setup: carpc + cap + amp + subs, etc mattress Power Supplies 3 04-11-2005 03:22 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
