Old 06-10-2009, 04:25 AM   #1
Austrazilian is an unknown quantity at this point
Opinions needed
Hi all i was wondering if i could get some help i have no idea about car audios so i have no clue what to get.
i have a hyundai hatch accent 99 model and wanteda decent sound system in it i saw this on ebay and was wondering id i could get some oppinions
http://cgi.ebay.com.au/NEW-6000W-AMP...QQcmdZViewItem
cheers thanks guys
Austrazilian is offline   Reply With Quote
Old 06-10-2009, 11:49 AM   #2
Sponge's Avatar
Sponge is on a distinguished road
I would not buy Kingwood. Here check this out:
http://www.mp3car.com/vbulletin/car-...-products.html
Sponge is offline   Reply With Quote
Old 06-10-2009, 11:18 PM   #3
nalav's Avatar
nalav is on a distinguished road
Don't bother with that system, you will be quite disappointed. It's comparable to buying a skateboard instead of a car for a 3,000 mile road trip. While some people might like the idea of a 3,000 mile road trip on a skateboard, they'd grow up before they made it 20 miles and buy some real audio equipment.
nalav is offline   Reply With Quote
Old 06-10-2009, 11:21 PM   #4
Thanks for the information also another thing i need to know is i have 4 speakers in my car and i want a sub will i need a 5 channel amp or does a 4 channel amp also support a sub thanks
Old 06-10-2009, 11:52 PM   #5
Sponge's Avatar
You need a channel per speaker, that includes the sub. You can run a single 5 channel amp or a 4 channel amp with a mono amp for the sub. Ok, get ready for some umbrella statements... (Disclaimer: not always true)
Single amp solutions (5 channel):
*Easier to install
*Space efficient
*Cost effective
*Limited availability and selection
*Normally a lower ceiling for power output
Multi amp solutions (4ch + mono):
*Flexible upgrades
*More selection
*Normally a larger footprint
*Higher ceiling for power output
Different 5 channel amps have different uses for their 5th channel as well. Some are designed for a center channel speaker (ie Alpine MRA-F350) while other are designed for a sub (ie Apine PDX-5). This is determined by their power output on the 5th channel.
Keep in mind!! Many will tell you that you need huge subs with gobs of power and this is simply untrue. In reality, many setups over 500w and a single nice 10"/12" sub are there for showoff (this assumes you are using decent to nice equipment and not kingwood ).
And read read read!
Old 06-11-2009, 12:00 AM   #6
lol thanks alot haha ye i think ill pass up on the kingwood lol i jus have no idea what to get tho now its a little more clear so i want a 5 channel amp since i have a small car it will save me space having jus a single one now how do i know which 5 channel amp supports subs and how many watts should i get in a sound system i want something decent and affordable lol
Old 06-11-2009, 12:10 AM   #7
jake789's Avatar
jake789 is on a distinguished road
6000W amp with 2x30amp fuses. 2000W 6x9's. Lucky you didn't buy that stuff, it is amazing at how low some companies will go...
jake789 is offline   Reply With Quote
Old 06-11-2009, 12:40 AM   #8
Sponge's Avatar
Haha, 2kw into 6x9s... I didn't even catch that.
Ok, now keep in mind, I'm just some stranger on the internet making recomendations... so do your research before buying. Here are some decent 5 channel amps that wont break the bank.
1) $199 Hifonics ZXi 8010 http://www.woofersetc.com/p7494/ZXi-...-Amplifier.htm
2) $289 Soundstream RUB5.800 http://www.woofersetc.com/p7764/RUB5...-Amplifier.htm
3) $349 Eclipse XA5000 http://www.sonicelectronix.com/item_...se+XA5000.html
4) $419 Alpine PDX-5 http://www.woofersetc.com/p6395/PDX5...ifier-PDX5.htm
I should mention that the power output on these 5 channel amps (~300w RMS) is not targeted towards driving a large array of subs or developing huge ground shaking bass BUT you will never find yourself without enough bass if that makes sense. Listen to some systems to get an idea of what you want in output. If sound quantity is what you are into (and thats cool too ) look at a two amp solution with a more powerful mono.
Edit: I forgot you are in "Austrazilia", might be a little more difficult to procure what I listed. You do get good prices on Morel speakers though. Lucky.
Old 06-11-2009, 01:19 AM   #9
Thanks for the info is there any threads that teach about car sound systems from scratch like what is a RMS or bridging
for example what does this mean lol
Power:
Channel 1 + 2 + 3 + 4:
70 Watts x 4 @ 4 Ohm
85 Watts x 2 @ 2 Ohm
Subwoofer Channel:
210 Watts x 1 @ 4 Ohm
420 Watts x 1 @ 2 Ohm
Max power output: 700 watts
MOSFET power supply
Old 06-11-2009, 02:29 AM   #10
Sponge's Avatar
Power:
Subwoofer Channel:
MOSFET power supply
That list of specifications outlines the power that the amp can output on each channel. Speakers have a large coil of wire which is going to have its own resistance. The @2ohms or @4ohms refers to the impedance (resistance) of the speaker that is going to be connected to it. The lower the impedance the more power (look at the ohms law section of your new bookmark), but keep in mind that doubling the power does NOT double the output of the speaker. Lost yet? Cool.
Bookmark this website: http://www.bcae1.com/
That site... well it's priceless if you are just starting out. Just use the right column to navigate topics. It should be your go-to for just about any concept of car audio. The information there is rock solid.
RMS: Basically means the voltage (amount of power) an amplifier can output and maintain continuously without clipping (distorting). You will see max power as well, this is not a good judge of the amps performance. Max power refers to a burst of power the amp can deliver for a split second.
Bridging: The act of physically wiring two channels on an amp to act as one, effectively combining their power.
Lots of good reading material here as well:
http://www.the12volt.com/ohm/basics.asp
Old 06-11-2009, 03:58 AM   #11
DJMikeT's Avatar
DJMikeT is an unknown quantity at this point
If you're not limited to a budget then I recommend the following:
JL Audio Amps:
300/4v2 Class A/B Four-Channel Full-Range Amplifier for mids and highs
500/1v2 Class D Monoblock Subwoofer Amplifier or
1000/1v2 Class D Monoblock Subwoofer Amplifier if you need the extra power
Sub Speaker or Speakers:
JL Audio W7 Subwoofer Drivers (they range from 8'' to 13")
Any speaker over 13" for a sub is a waste, JL Audio is the undisputed champion on Audio sound and they won't make a speaker over 13" because of distortion.
I have 2 JL Audio W6 10" Subs in my Durango and it sounds absolutely amazing, just like being in a Club. Very clean and tight bass even at high levels.
Mid and High Speakers:
Focal (any of their series) but the Utopia Series are the best but very expensive. Their sound is unbelievable, if your an audiophile you will really
appreciate these.
Now keep in mind this equipment is not cheap. Hence like I said if your not a budget. I always go first class when it comes to sound even if it does cost more or a hell of a lot more, lol.
Oh BTW, check your local Craigslist, I've been seeing people hurting for money selling their JL Audio gear at really cheap prices.
DJMikeT is offline   Reply With Quote
Opinions on this setup ... DarthMandarb Newbie 2 02-17-2007 09:51 AM
Expert opinions needed on Pioneer TS-SW2541D Shallow Subwoofers bambam Car Audio 13 12-02-2006 10:42 PM
My Planned System, Opinions Needed Wilsman00 Newbie 19 10-14-2006 05:30 AM
Diamond Audio D5 600.2 Amp (opinions needed) aaardal Car Audio 2 08-11-2006 11:13 PM
Opinions & Feedback needed (new music) PianoJay General MP3Car Discussion 0 08-18-2000 07:09 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
