Quote: Originally Posted by
Ben_Jamin
The car i am getting is a saxo furio, anyone know of speakers that would fit in the front of this car ??
From
here it looks like your fronts are 13cm and your back is 10cm. So 13cm would be around a 5.25" speaker.
Basically for a good system, you will want:
Front speakers: Quality Component set
Back speakers: Quality 2-way speakers
Amp1: 4 channel to run all the speakers
Amp2: 1 channel to run all the subs
Because you have brands over there that I've never heard of in the states, here is a good way to tell the real power of the amp. Use this equation:
(fuse total) x 13.8 (common battery voltage) x 80% (fuses are generally rated at 20% over max power).
So if you see an amp that has 2 50amp fuses, then (100 x 13.8 x 80%) = 1100 watts max power.
Thats a very basic way to tell but if you aren't familiar with brands it is a good idea to keep it in mind.
