Old 06-11-2009, 03:51 PM   #1
armysgt's Avatar
armysgt will become famous soon enougharmysgt will become famous soon enough
Help wiring into stock amp wiring harness
I have a soundblaster live 5.1 card I need to hook up to my car's stock infinity amp wiring harness. The harness is the only input/output on the amp. I need to wire two stereo cables into it.One for the front speakers, one for the rears. I have the sub taken care of. How do i splice these stereo cable into the harness. I know what colors the wires are and everything, I have the speaker wiring diagram. Any help would be appreciated, I'm tearing my hair out.
Electronic Space Foot
armysgt is offline   Reply With Quote
Old 06-11-2009, 04:13 PM   #2
soundman98's Avatar
soundman98 has a spectacular aura aboutsoundman98 has a spectacular aura aboutsoundman98 has a spectacular aura about
Being that you already know what colors are what, you will just need to make sure that the amp accepts a low level input, instead of a high level, if it takes a high level, none of this will work. If it does accept a low level input, then cut the headphone cable there should be 2 wires a shield. the wires are the left/rightpair, and the shield is ground. the ground will need to be wired to both negative speaker leads, and the left / right should be to the positive leads. wire colors change between manufacturers, so it would be best to check which is which before hard wiring anything.
soundman98 is offline   Reply With Quote
2007 Ford Fusion Carputer (version 2.0) FusionFanatic Show off your project 43 04-20-2009 05:56 PM
Wiring up an amp Leonfoster Newbie 0 10-10-2008 04:05 PM
Wiring CarPC from Amp wiring? Calipso Newbie 6 02-03-2007 06:32 PM
Need some help with sending audio to stock amp orangewhip General Hardware Discussion 12 09-04-2003 02:21 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
