Old 07-02-2009, 09:03 AM   #31
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
now i just need to figure out the best way to control 3 stereo lines, both independantly, and as a master volume (will be running a full active setup, so I need control over each set of speakers).
right now the only way i can figure to do this would be to use 6 of the jl units, 3 of them coupled togather for master volume, and the another 3 for idependant adjustment... any other ideas?
soundman98 is offline   Reply With Quote
Old 07-02-2009, 10:31 AM   #32
pcpete's Avatar
pcpete is on a distinguished road
Quote: Originally Posted by WuNgUn View Post
Well, now we know!!
Isn't having 2 knobs for your mids and tweets kinda redundant? Couldn't you just get away with using a single controller on your tweets, for example, and use your master volume to adjust everything else?
Or is this to adjust your mids/tweets seperate from your subs as well?
I use one for tweets, and one for sub. The mids don't have one, I use master volume for that, and adjust tweets and sub to match...
pcpete is offline   Reply With Quote
Old 07-02-2009, 10:53 AM   #33
WuNgUn's Avatar
WuNgUn is on a distinguished road
Okay...that makes sense.
WuNgUn is offline   Reply With Quote
Old 07-02-2009, 10:57 AM   #34
WuNgUn's Avatar
I'm in a similar situation...
I'm running active 2-way's to 4 corners of my car...there is just no easy way to control the output with a 2-channel volume control.
I imagine a 2-channel, S/PDIF output going to a DAC (or a 2-channel analog output from a seperate soundcard?), from the DAC to the volume control, then back to the Line-In of the sound card, DSP, then analog output from the sound card jacks to the amps...
Old 07-26-2009, 11:03 PM   #35
Whitebread is an unknown quantity at this point
Would it be possible to use a stepped attenuator on the sound card output? I've done this in home audio setups but, I don't know how the fidelity would fare with the decrease in line voltage at lower volumes.
Whitebread is offline   Reply With Quote
Old 07-27-2009, 09:44 AM   #36
soundman98's Avatar
i beleive that this idea is a very similar to both ideas that were discussed in this topic--using either the jl unit, or using a audio distrobution volume control after the amps.
after thinking about it for a while, i really think that the jl unit is the best peice to use overall-- simply becasue it has a 5volt preamp, and a volume control.
i am not very familiar with stepped attenuators, but like you said, without a preamp, there is not very much voltage behind sound card outputs, so for any other solution to work, you would need a preamp, and then the volume control, which will get you up to the same price as the jl unit (roughly $50 each-depending on purchasing location)
Old 07-27-2009, 06:36 PM   #37
If the JL unit is only 50 dollars, I'd go with that. Something simple like a 46 position stereo stepped attenuator with quality resistors can run 200 dollars. Those of us with active crossovers and multi way stages would need many times more complex units that would run well into the thousand dollar area.
Old 07-28-2009, 09:40 AM   #38
soundman98's Avatar
for one, i wouldn't mind the $50 price tag, but i need 3-6, depending on how i decide i want to set it up(one vol control-need 3-i have a 3way active setup, and/or independant vol control for each speaker pair-would need another 3), and $50 adds up pretty quickly (my wallet checked into therapy after the original carputer build). although i really havent seen anything that compares, so, it might be one of the only active setup options under $100...
Volume control on PC or headunit? efun Car Audio 10 01-15-2009 10:48 PM
Volume Control? Teebs Road Runner 5 12-12-2008 03:57 PM
Volume control does not work with USB soundcard (Turtle Beach Audio Advantage Micro) nobb CF Bug Reports 0 12-01-2008 05:48 PM
Soarer Volume Control Beezer Hardware Development 13 04-28-2007 12:25 PM
Change behaviour Volume control DbXL Centrafuse 0 07-09-2006 12:09 PM
