Old 06-20-2009, 03:11 PM   #1
summer69guy is an unknown quantity at this point
3.5mm jack to 2 femelles rca
Do you think this with two femelles rca will have good quality for an sq ssystem ?
or do you have another thing like this whop will have verry good sound quality...i want i very clean signal.
i alrealdy have my rcas installed
summer69guy is offline   Reply With Quote
Old 06-20-2009, 03:48 PM   #2
PaulF's Avatar
PaulF is on a distinguished road
That link takes you to a login page.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Old 06-20-2009, 04:09 PM   #3
thanks
Old 06-20-2009, 05:05 PM   #4
PaulF's Avatar
I'm sure the sound quality you will get out of that device will be fine. But without the actual specifications of it, I can't give you a real answer.
Those adapters are cheap enough that you can buy a few different ones and try them out to see which sounds best to you. Usually I go to radio shack for things like that.
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 06-20-2009, 06:07 PM   #5
jake789's Avatar
jake789 is on a distinguished road
Don't think it would affect the sound as long as its not too cheap.
I would pick this style personally
http://www.monoprice.com/products/pr...seq=1&format=2
jake789 is offline   Reply With Quote
Old 06-20-2009, 10:35 PM   #6
colin's Avatar
colin will become famous soon enoughcolin will become famous soon enough
There's no cable runs so you shouldnt notice any difference in the quality. Should be okay.
2001 Mustang Convertible Worklog
Indigo Custom Frontend (Flash/Delphi)
Blog
Code:
Currently: - Working on my new product! Wiring: |■■■■■■■■■■■■■■■■■■--| Trunk: |■■■-----------------| Sound: |■■■■■■--------------| Screen: |■■■■■■--------------|
colin is offline   Reply With Quote
Old 06-21-2009, 05:57 AM   #7
Un_discovered is on a distinguished road
Copper is copper, unless the adaptor you buy is so cheap that it's faulty out of the box, then you won't hear any difference.
I would recommend using a cabled jack to 2x RCA cable, as this won't put excess weight on the flimsy 3.5mm jack, whereas the above adaptor will, and thus, can shorten the life of the jack socket in whatever it is connecting to.
Un_discovered is offline   Reply With Quote
Old 06-22-2009, 04:04 AM   #8
joey7415963 is an unknown quantity at this point
let's put it this way:
Your not going to notice any difference in quality if you used platinum contacts or copper contacts. Your in a car there will be plenty things masking the quality of the sound!
joey7415963 is offline   Reply With Quote
RCA Jack for 2002 Volvo S60 PaulF Newbie 7 01-21-2008 10:04 PM
Sound quality of running 3.5mm into RCA and then outputting to subs? AznArkitekt Car Audio 5 10-12-2006 11:25 AM
simple question - mounting a 3.5mm (1/8") jack bodaciousllama Fabrication 3 04-18-2006 07:52 PM
could I connect a laptop headphone jack to a radio with an Aux in rca plug. Amax Car Audio 2 03-01-2005 06:23 PM
How to connect 1/8in (3.5mm) audio card Line out to the car's Aux RCA Input? Magnum General Hardware Discussion 8 06-03-2001 09:16 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
