Old 06-22-2009, 02:41 PM   #1
soundman98's Avatar
soundman98 has a spectacular aura aboutsoundman98 has a spectacular aura aboutsoundman98 has a spectacular aura about
Pci riser cards, what to use?
So like the title says, what kind of pci riser card is best for sound cards?
I am using a Intel D945GCLF, and my mounting location has a maximum height of 2", so any sound card must be mounted on the same plane as the mother board.
I have been using this: http://www.comix.com.tw/products/RC/392.jpg
but have recently run into a problem where havving the riser card plugged in will not allow the system to post. as soon as I plug the sound card directly into the mobo pci slot, or unplug the whole thing, it will boot fine.
If no one has any solutions to correct this problem, I will be looking for recomendations on a usb sound card.
Thanks!
soundman98 is offline   Reply With Quote
Old 06-22-2009, 02:51 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
That riser you have is a good solution. There really isnt any reason why it wouldnt post other than a defect in the riser. I am guessing cheap ebay/china buy right? It should just be a 1-1 extension of the PCI port. So if you plug it in, nothing should happen. If something happens when you plug it in (i.e. no post), then there is a defect in it somewhere.
I would just order another of those and hope it is not faulty.
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
PCI Riser cards question Emo General Hardware Discussion 2 06-22-2006 08:14 PM
Dual PCI riser cards Arathranar General Hardware Discussion 4 10-17-2004 12:18 AM
Ribbon PCI riser cards w/ 2 slots??? wompser General Hardware Discussion 4 01-15-2004 06:22 PM
PCI riser cards Zensay General Hardware Discussion 16 10-19-2003 09:52 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
