Old 06-24-2009, 11:11 AM   #1
jellymonster is an unknown quantity at this point
Exclamation Amp protect light on :(
When I'm driving, at random my music will just stop. I pull over look at the amp, and the red protect light is on instead of the green power light.
At the moment I have my carputer outputting into the 2 RCA inputs. The computer and amp are both grounded to the same place.
I only started happening when I replaced the stock HU with the computer.
What is the cause. Is it yet another dodgy grounding or something else?
I also have a sub, 2 6x9's and 2 5.25" speakers powered from it.
JM
jellymonster is online now   Reply With Quote
Advertisement Sponsored links
Old 06-24-2009, 11:24 AM   #2
thekl0wn's Avatar
thekl0wn is on a distinguished road
Is it a 5/6-channel amp? If not, you've probably got some serious issues going on with that end of the wiring!
A bad ground can cause this. Overheating can cause this. Something broke in the amp can cause this. Clipping can cause this. etc.
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
thekl0wn is offline   Reply With Quote
Old 06-24-2009, 12:11 PM   #3
it's a 4 channel 1000W amp. When I felt it, it did feel quite hot :S.
Are there any troubleshooting methods u guys have?
Old 06-24-2009, 12:27 PM   #4
thekl0wn's Avatar
How in the heck is that thing wired?
And what kind of amp is it? Almost any amp is going to get hot. It's just a matter of how hot.
Old 06-24-2009, 12:33 PM   #5
I have a blaster bl-1000 amp.
I have the amp plugged into battery through 30A fuse. Sub bridged with 2X250W ports. The 6X9's and 5.25"s are plugged into remaining 2 250W ports.
PC is plugged into battery and ground is in amp ground port (also grounded to chasis).
The amp turns on via PC remote (m4-atx).
Anymore info needed please state
JM
Old 06-24-2009, 12:48 PM   #6
soundman98's Avatar
soundman98 has a spectacular aura aboutsoundman98 has a spectacular aura aboutsoundman98 has a spectacular aura about
are the 6x9's and 5-1/4's wired in series or parallel, and what is the end load on the amp(measured across the output terminals of the amp)?
also, what type of subwoofer(brand, model #) and how is it wired if it has more than one voice coil? and again, what is the end load on the amp?
how hot did the amp get? most amps, when they get hot enough to go into protect will be hot enough to burn you.
I did a very brief search(very brief) and did not see anything about the amp being 2 ohm stable, so i have a hunch that you will find that either the end load is 2 ohms(for either the sub or speakers) or that you have a grounding issue.
soundman98 is offline   Reply With Quote
Old 06-24-2009, 01:27 PM   #7
The 6x9's and 5.25" speakers are in parallel.
Amp speaker ports (250W) each.
1) One Kenwood KFC-M6942A speaker and Kenwood KFC-1350S speaker both in parallel.
2) One Kenwood KFC-M6942A speaker and Kenwood KFC-1350S speaker both in parallel.
3 + 4) Bridged kfc-w3011
The amp was definately not hot enough to burn me, so I guess that's out of the picture.
How do I measure the end load?
JM
Old 06-24-2009, 01:28 PM   #8
o and before I replaced the HU for the computer, I had all speakers except the 2 - 5.25" speakers plugged into the amp all running fine.
Old 06-24-2009, 01:48 PM   #9
soundman98's Avatar
to measure the end load, unplug the speakers from the amp, and put a ohm meter across the 2 connections.
I think that this is where the problem is-- having 2 speakers parallel for each channel will produce a 2 ohm load. try hooking the speakers up in series. this should produce a 8 ohm load, but will be alot quieter, and will not send the amp into protect.
Old 06-24-2009, 01:55 PM   #10
ok, I will give that a go. At the moment I'm sorting out yet another problem, hopefully I will get a chance to test it tonight .
Thanks for your help.
Old 06-24-2009, 02:27 PM   #11
roflcopter's Avatar
roflcopter is an unknown quantity at this point
i'm no expert, i dont even have an answer to my speculation, but when you bridge your sub, that changes the load. when the 1/2 channel impedance doesn't match the 3/4 impedance, doesnt that cause a problem?
also, some amps are not bridgeable which maybe an issue. make sure your amp exclusively states that its bridgeable.
2007 Saab 9-3ss 2.0T
Jetway J7F5M1g5d-VHE-LF, 32gb patriot SSD, 160gb WD hdd, nLite XP sp3, EWF/Horm, RideRunner
Current Progress:
PC
HARDWARE [100%] SOFTWARE [95%] FABRICATION [100%] INSTALL [75%]
Workblog
roflcopter is offline   Reply With Quote
Old 06-24-2009, 02:50 PM   #12
WuNgUn's Avatar
WuNgUn is on a distinguished road
Remember, bridging and parallel are two seperate things...
Bridging is when you combine the amps load over 2 channels...
i.e. a typical, single sub bridged would look like sub + to LEFT + amp connector, sub - to RIGHT - amp connector...
Bridged over 2 channels...
Paralleling is combining more than one speaker to a channel...speaker A and speaker B both connected together to the amps left channel for example...
This HEAVILY loads the amp (making the output louder) but also raising thermal issues with the amp, which could lead to load protecting.
SoundMan is right...you should run then in series to spare your amp any harm. Of course doing so, you'll also decrease the output.
Your best solution is another amp for your extra speakers...
WuNgUn is offline   Reply With Quote
Old 06-24-2009, 05:17 PM   #13
ok, my amp is bridgable and my sub seems to be working fine. Has done even with old HU.
I will put the others speakers in serial and see what volume difference it makes. I can always increase the gain for them. If it is too much of a decrease, I will think of another amp, but I don't know how much more power my alternator can handle :S.
Thanks for your help guys, I will post back with the results.
Old 06-25-2009, 08:11 AM   #14
WuNgUn's Avatar
JM
A 'Blaster' amp? Never heard of 'em...
So your running a sub AND 4 sets of drivers off this one amp?? And it's fused at 30A? I must of missed that reply...
Each pair of CHANNELS on my TRU amps are fused at 30A (4 channels) and they are rated for 'just' 65 watts output. The power line from the battery (4awg) to these amps is fused at 80A.
I have a very hard time believing this Blaster is a 1000 watt amp...it would likely melt at 30A fuse if it were!
I would buy another amp just for the sub, then seperate your drivers into their own channel on the Blaster, and all should be fine.
Old 06-25-2009, 09:05 AM   #15
Crinos is an unknown quantity at this point
The amp can be 450watt at max with a 30A fuse, based on 15v current.
This would be true if you had a class-d amp... well.. kinda true.. the best amps can give you as much as 98% effect.
For a normal class-b amp, you would have something like 300watt
the "blaster" is probably 1000w PEAK...
But, to answer your question...
It looks like your overpowering the amp, so that it goes hot, and shutsdown. Even thought the casing of the amp is not hot enough to burn you, the components can be to hot... especially if they are of the cheaper type.
Whey buying an amp, "getting what you pay for" is a true statement..
Crinos is online now   Reply With Quote
Tags
amp, light, protect, protect light, rca
Unusual amp shut off problem....please help! mike40370 Car Audio 12 12-05-2007 05:13 PM
Can I run this amp with this sub, how do ohms work, help/recommendations... mikeym Car Audio 37 02-12-2007 12:10 PM
Amp running hot...?? Emerica2843 General Hardware Discussion 5 02-08-2006 06:40 PM
Amp running hot...?? Emerica2843 Car Audio 6 01-29-2006 08:29 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
