it works on front audio connection, but not rear connections
I was able to make it work with the front connection on the case. Using a 3.5 mini splitter, I was able to send a connection from the computer to the 2 amps. I'm not sure why it won't work from the connections off of the motherboard at the back of the computer, any thoughts on why this might not be working?
I had the 2-channel amp (my stereo amp for now, want to switch to 4-channel soon) connected to the green connection and the sub amp connected to the orange connection that said center/sub. None of the outputs at the back of the computer worked, though. Previously, I had a different case that also had the audio connection up front, but the rear output worked also, that is what I used to connect my speakers at home to.
I used the azalia connection for the front audio connector and am wondering if that might be the reason.
