Old 06-30-2009, 03:52 PM   #1
spoolup is an unknown quantity at this point
whine whine whine
hey guys,
little issue with engine whine.
in know it's a common thing on carpc's but the scenario is a bit odd.
i'm running my mobo's audio out thru my headunit aux in.
the whine is "selective"
sometimes it will be there sometimes it won't.....
i run the 5 foot wire thru a ferrite magnet and the distance between audio out to aux in is a foot apart.....
any ideas?
thx
i thought of a loop isolator, but it seems overkill
spoolup is offline   Reply With Quote
Old 06-30-2009, 04:04 PM   #2
soundman98's Avatar
soundman98 has a spectacular aura aboutsoundman98 has a spectacular aura aboutsoundman98 has a spectacular aura about
it might be related to another device that you are plugging in, could you list your dc-dc power supply, and head unit brand/model#?
soundman98 is offline   Reply With Quote
Old 06-30-2009, 04:10 PM   #3
i got n m1atx powering a dual core atom (intel) 1gb board. powered off the battery and the switch is off the headunit's harness.
headunit is blaupunkt brisbane sd48.
the only other devices plugged into the pc are usb extension to the screen and gps.
sound from the headunit is superb when on radio.
once aux in is selected, like a said, it's a hit and miss.....
Old 06-30-2009, 04:37 PM   #4
jpinkerton's Avatar
jpinkerton is on a distinguished road
Outta curiosity, do you have the power lines to M1ATX alongside the audio?
jpinkerton is offline   Reply With Quote
Old 06-30-2009, 04:43 PM   #5
don't think so.
i'll take the cover out tomorrow and let you know.
but i think they were on the opposite sides of the voompc case.
but the power lines are next to the audio jacks....
Old 06-30-2009, 05:10 PM   #6
pathfinder123 is an unknown quantity at this point
Whine, crackles and other noises are generally caused by earthing problems.
Fit a ground isolator. At less than £15 it's a no brainer.
Despite taking a lot of care with my installation, I still had a lot of noise.
Fitting an isolator took 5 mins and got rid of all the noises.
Cheers
Stewart
pathfinder123 is offline   Reply With Quote
Old 06-30-2009, 05:27 PM   #7
jpinkerton's Avatar
Where is the line from VoomPC to head unit in relation to the line from the battery to the M1?
Old 06-30-2009, 07:13 PM   #8
unfortunately they are pretty darn close.
reroute in progress with ground isolator in the morning.......
thanks guys.
i'll post results.
P
Old 07-01-2009, 08:40 AM   #9
zillacles is an unknown quantity at this point
After you reroute try it without the groundloop isolate first, because you might find you don't need it
zillacles is offline   Reply With Quote
Engine Whine when air con is switched on..... shabz34526 Car Audio 23 04-15-2009 11:12 PM
Odd Alternator Whine Problem? blafrisch Car Audio 9 10-01-2006 12:57 PM
Strange alt whine when more than 2 channels (LONG) vettejock99 Car Audio 4 02-26-2006 12:38 PM
Engine whine - help... Pseudo Nim Car Audio 7 08-14-2005 12:57 PM
Engine whine RANT maxxell Car Audio 6 08-13-2005 12:04 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
