Old 07-01-2009, 09:02 AM   #1
ryanricheson is an unknown quantity at this point
Sony xplod HU over heating?
So my buddy helped me for a bit yesterday to get the CD player (sony Xplod) hooked up in my boat....but now the back of it gets pretty damn hot (hot enough to burn me if I touched it..... Options:
1) the old am/fm radio that was in there had a much smaller fuse so maybe its getting hot because of that...
Fix: replace fuse with bigger fuse
2) the old radio didn't need a as much power so the new radio is trying to pull to much power from the helm.
Fix: run power back from the battery
3)the old radio had all seperate "possitive" wires fo the four speakers but the left and right side speakers shared a "negative" wire.... on the new radio this might be creating to many ohms and causing to much resistence causeing it to heat up.
Fix: run seperate "negatives" for each speaker
4) a few people said that the back of the radios do get hot and not to worry about it, espesially the sony's. (however it burn me when I touched it so im thinkng that maybe its too hot.)
Any ideas?
ryanricheson is offline   Reply With Quote
Old 07-02-2009, 10:35 AM   #2
soundman98's Avatar
soundman98 has a spectacular aura aboutsoundman98 has a spectacular aura aboutsoundman98 has a spectacular aura about
with newer radios, they are more sensitive to the way they are hooked up-- you will need to run separate + and - wires to each individul speaker, this should cure the heat issue.
soundman98 is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
