Old 07-06-2009, 02:43 PM   #1
danimal is an unknown quantity at this point
Death by bass?
I have a pretty substantial system in my truck, and got to thinking today how well my car PC is going to hold up through all that pounding.
Any ideas or prior experience with this kinda sittuation?
im looking at roughly 120 130 DB
danimal is offline   Reply With Quote
Old 07-06-2009, 03:02 PM   #2
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
as long as your computer is securly bolted down, it should be ok. just don't let any computer components rattle too much .
a little OT, but what equipment are you running to get 120-130db?
soundman98 is offline   Reply With Quote
Old 07-06-2009, 03:18 PM   #3
two 12" 1800W fubars and a 3000W mono block amp. ported box tuned to 45- 50 hz
Old 07-06-2009, 03:46 PM   #4
PaulF's Avatar
PaulF is on a distinguished road
As long as everything is bolted down, the hard drive is the only problem. That will tear a hard drive apart. You should look int a solid state disk.
My Car (Just the audio install as of now)
http://paulfurtado.com/car/
Worklog:
http://www.mp3car.com/vbulletin/work...-work-log.html
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
PaulF is offline   Reply With Quote
Old 07-06-2009, 04:06 PM   #5
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
I think you ears are more likely to fail before the PC does.
Enforcer is offline   Reply With Quote
Old 07-06-2009, 04:48 PM   #6
soundman98's Avatar
i really think the whole SSD argument is getting blown out of proportion for a lot of people. do a search for the couple of threads/arguments on hdd placement/orientation(horizontal/verticle). there was member that has put laptop drives in small military boats--a very harsh environment--said that the marines that ride in the boats have been known to shrink from the force of the boat going over waves, claimed that the drives are doing fine.
unless the OP were to mount the hdd directly over a sub and mount it loosely, the spl shouldn't affect it very much, assuming that it is mounted to a firm surface.
EDIT: i would be very interested in any data anyone has to disprove any points i have made, so far, i have not seen/read anything to justify that a ssd drive is better in a vibration prone install.
Old 07-06-2009, 05:05 PM   #7
PaulF's Avatar
Hard drives can handle bumps, they can't handle constant vibration though. I don't care if you mount the thing to a block of cement, the thing is going to vibrate in that car if his sub is putting out 130 db. Look at the threads on this forum showing people who mount their hard drives in the same trunk as a serious subwoofer. Sure there are hard drives that are rugged enough to handle it, but they cost as much as an SSD anyway. An SSD has no moving parts that can get messed up therefore a subwoofer can't kill one unless it makes the solder come apart.
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 07-06-2009, 05:14 PM   #8
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
IF you are worried about vibration, THEN use either an automotive grade HDD (you can find them on the mp3car store) or an SSD.
On the other hand, if you already have a drive, by all means, try it out and see. I second the notion that you ought not put it close to your subs, but as long as you aren't mounting it to a surface that will vibrate due to the sub, the HDD enclosure will protect the platter by reflecting much of the sound. I'd go with bolting it securely to something firm or just keeping it out of the line of fire.
Nobody on this board has quantitative data on HDD vibration but I can't recall a case where it has been a problem in a car with a regular sound system. Most of the time I've seen people fault the hard disk, it turns out to be a connector or power problem.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 07-06-2009, 06:29 PM   #9
Well sounds good Ill post up my results after i have the subs pounding for a while and see what that dose to the HD
Old 07-07-2009, 10:14 AM   #10
nalav's Avatar
nalav is on a distinguished road
Working on my truck (well mostly just ordering stuff for it now) and I'm going to try out Seagate's EE series hard drive. I also have some mounting options in my mind that should help out with the vibration. My truck will have 3 12" Fi Qs (dual 1ohm) with a 1200 watt RMS AudioQue amp for each one. I'll post in a few months when I get it all completed whether my drive lasted or not
nalav is offline   Reply With Quote
Old 07-07-2009, 10:59 AM   #11
nicr4wks is an unknown quantity at this point
Interested to see how this goes, just ordered a screen and in the planning stages of my first car-pc. I already have a decent amount of audio equipment in the car to the point that if i play a 10hz test tone around 30% volume you can see the back seat flexing in and out, behind the seat there is a solid metal plate, then the car battery, some rear-wheel steering computers then the subs in the boot so that's quiet a lot to get through to make the back seat flex the way it does, not to mention the various vibrations and flexing that occurs during normal audio play back.
Working with PC hardware for 14 years I can't imagine any mechanical hdd is going to withstand that sort of torture if placed in the boot no matter how it was mounted.
nicr4wks is offline   Reply With Quote
Old 07-07-2009, 11:19 AM   #12
CyberStingray's Avatar
CyberStingray is an unknown quantity at this point
Sound will affect the drive... see these test results for proof...
http://www.youtube.com/watch?v=tDacjrSCeq4
http://blogs.sun.com/brendan/entry/unusual_disk_latency
That being said, make sure you have an image of the drive and try yourself...
CyberStingray is offline   Reply With Quote
Old 07-07-2009, 12:24 PM   #13
Maheriano will become famous soon enoughMaheriano will become famous soon enough
It's not so hard, I hit 137.5 in a DB Drag competition with just this:
- JVC El-Kameleon KDLX-30 headunit
- Rockford Fosgate HE2 12 inch subwoofer
- Rockford Fosgate 250m Power amplifier
That was with a 250 watt amplifier so if you're running a 3000 watt and only hitting the same range, it's either not class D or you don't have it hooked up properly. The SQL was really good on it too.
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 07-07-2009, 12:38 PM   #14
PaulF's Avatar
Where were you holding the db meter?
Worklog:
Planning 90%
Computer Build 88%
Programming 10%
Car Install 71%
Old 07-07-2009, 12:42 PM   #15
meter was the same in every car, it was on a stand on the passenger side in front of the glovebox. Engine was revved to 2500 RPM for the drag and it was in a 2000 4 door Cavalier with stock battery/alternator.
Ampie Case
256 MB DDR2 PC5400
M2-ATX-HV
2005 Honda Civic
System Choices and Questions BoondockSaints Car Audio 85 08-09-2007 11:52 AM
Bass channel not loud enough spoonraker Car Audio 6 01-14-2007 10:18 PM
bass boost tundra2000 Road Runner 7 07-17-2006 01:10 PM
How do you control Bass?? PhatMo Car Audio 15 06-16-2006 11:09 PM
MP3's bass is too flat Nicorolla Software & Software Development 17 11-05-2004 09:13 PM
