Old 09-24-2009, 12:35 PM   #1
SebLex is on a distinguished road
Making my own RCA aux-in on back harness of headunit ?
Hi all,
I don't have an aux-in on my headunit. Is there any way I can splice in the back harness with my 2 RCA wires coming from the computer?
SebLex is offline   Reply With Quote
Old 09-24-2009, 12:42 PM   #2
CMOS1138 is an unknown quantity at this point
that depends on if you have an amp or just the head unit.
if you have an amp, yes you can splice into the wiring harnis but you will get sound output all the time from the headunit and the carputer and the headunit will not control the carputer's volume.
if you don't have an amp, no, this will not do anything .
CMOS1138 is offline   Reply With Quote
Old 09-24-2009, 03:26 PM   #3
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
if your radio is capable of adding a aux in, cd changer, or ipod hook up, than you might be able to hook up the the deck, otherwise, what cmos said
soundman98 is offline   Reply With Quote
Old 09-24-2009, 04:47 PM   #4
bobdole369 is an unknown quantity at this point
One further issue:
You are playing your aux input across the output fets of the head unit. On my head unit, this causes distortion. I made a relay setup that senses the jack insertion.
bobdole369 is offline   Reply With Quote
Old 09-24-2009, 05:26 PM   #5
hithere is an unknown quantity at this point
Just wanted to say that if your head unit has a changer port (there aren't many that don't), there are many commercially available means to make that into an aux input. You can also sometimes splice into an existing changer/Sirius/XM input cable and provide an additional input via a headphone jack that will interrupt the changer/Sirius/XM input in favor of whatever you plug into it. You could equip such a splice with a manual a/b switch.
You could also A/B switch the output of the head unit (RCA's to your amps) with your computer output.
I have too much time and too little aggravation in my life, so I built a carPC. ;)
hithere is offline   Reply With Quote
Old 09-24-2009, 05:27 PM   #6
No cd changer port either.
Looks like I'll have to wire in my other Sony headunit that has the aux input! I'm just afraid of the sound quality VS the JVC.
Old 09-24-2009, 10:03 PM   #7
trader007 can only hope to improve
as much as sony sucks, it really shouldnt make that big of a difference.
trader007 is offline   Reply With Quote
Old 09-25-2009, 06:59 AM   #8
atrixstars's Avatar
atrixstars is an unknown quantity at this point
if you have aux-in. Chances that if you know which wirings you can splice some together with the rca cable to make two. I seen it done in aftermarket HU setups.
atrixstars is offline   Reply With Quote
Old 09-25-2009, 07:49 AM   #9
leo_bergamo's Avatar
leo_bergamo is on a distinguished road
Hello
Hey do some research on your head unit. I researched my Pioneer and learned how to make a homemade AUX adapter the AUX adapter from Pioneer was $50. If you are familiar with pin-outs and low voltage wiring and a hot glue gun then resort to this.
Leo
leo_bergamo is offline   Reply With Quote
Old 09-25-2009, 12:15 PM   #10
Well I have nothing against Sony, it's just that I had that head unit in my other car and with the volume loud, the sound would distort enough that I thought my speakers were shot (factory speakers). I replaced that unit with a Kenwood unit that I really really like that was worth near 600$ in 2002 and the speakers played like new ones.
Now in my current car, 2002 Lexus IS300, I have great factory speakers that work like a charm with the JVC head unit. Really it sounds great and no distortion when loud. I'm just afraid to loose that great soud if I install the Sony. I've never tried it in that car so I have no clue of how it will sound.
But then again, like you say, it may not make a big difference, both the JVC and Sony I have are low end 120 - 140$ head units. The Kenwood in that car would be incredible but I sold it to my mother. I might try to trade with her if the Kenwood has an aux-in! hehe
Leo
Really? Do you have a suggestion on where to search?
Thanks all for your comments!!
Old 09-25-2009, 12:26 PM   #11
It has the AUX input in the rear, I just need to buy the 5$ cable that has the RCA inputs on one end and the special plug for the rear!
Old 09-26-2009, 09:26 AM   #12
Well you made out then. Pioneer is a little pricy. But have found ways of fabricating homemade plugs for both Pioneer and Kenwood.
Old 09-26-2009, 09:54 AM   #13
As far as search suggestions, I mainly just inputed into ever so cumbersome Google my head unit make and model and followed that with something like DIY aux cable.
Old 09-26-2009, 11:44 AM   #14
sounds like youre running the speakers directly off the radio, in that case there would be a concern about your headunits quality. if you have an amp though, and are just using the headunit for inputs and light equalizing its usually much less noticeable what you have there.
i did the input mod to my pioneer too. all i did was take like 18awg speaker wire, cut the end flush, and jam it onto the pin it needed to go to. do that to the other 3 wires and secure the group with epoxy. permanent pigtail aux rca input.
Need help with a Ford Taurus 2002 stock stereo markis00 Car Audio 57 06-02-2009 12:28 PM
went back to (had to) stock headunit :( americasfuture2 General MP3Car Discussion 6 03-22-2008 09:38 PM
How to get to back of headunit nick8197 Newbie 9 02-11-2005 12:55 PM
Sony headunit Aux.. help needed CdRsKuLL General Hardware Discussion 11 02-27-2004 02:47 PM
FA: Half of sony unilink cable -> GNUnilink (aux in & display text on headunit) infrared Classified Archive 0 02-11-2003 02:15 PM
