Old 09-25-2009, 06:47 AM   #1
atrixstars's Avatar
atrixstars is an unknown quantity at this point
Amp to Carpu with no Headunit?
Hi, I searched and found few threads but incomplete answering the same question. I want to be able connect my amp/speakers (Factory Bose) to my carpu soundcard with no headunit. The reason for that is because I upgraded to a 7" double-din which I took the factory HU to fit the screen. I might in the future get a alpine or pioneer HU. But now I want to used the amp without a headunit.
I found this item. Anyone think it works like how I want it to?
http://www.crutchfield.com/S-1zEkakL...PAC-OEM-2.html
atrixstars is offline   Reply With Quote
Old 09-25-2009, 07:39 AM   #2
MrZ
MrZ's Avatar
MrZ is an unknown quantity at this point
First you have to know if your factory amps take line signal or speaker-level signal. If they work with speaker-level signal you will need to send an amplified signal as it came out of the original HU.
In that case I'd suggest the Xtronic USB Amp.
MrZ is offline   Reply With Quote
Old 09-25-2009, 07:44 AM   #3
leo_bergamo's Avatar
leo_bergamo is on a distinguished road
Hello
Hello,
From my experience most amplifiers will work fine when connected to the the "line out" on your sound card. You will need a 3.5mm phono to RCA adapter or sometimes known as a mini "Y" adapter. Hope this helps!
Leo
leo_bergamo is offline   Reply With Quote
Old 09-25-2009, 09:47 AM   #4
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
http://www.mp3car.com/vbulletin/advfaq.php
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-25-2009, 10:01 AM   #5
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
Quote: Originally Posted by leo_bergamo View Post
Hello,
Leo
this will work fine for aftermarket amps, but factory amps are all over the board-- even in the same model car... if your amp is looking for speaker level inputs, this will not work, but if it has line level inputs, this will work...
soundman98 is offline   Reply With Quote
Old 09-29-2009, 01:44 AM   #6
YESindeed can only hope to improve
if it is a factory GM bose, it will most likely take line level. if its Japanese bose, it will most likely take speaker level.
YESindeed is offline   Reply With Quote
Old 10-05-2009, 01:34 PM   #7
atrix415 is an unknown quantity at this point
But how would I connect the factory speakers+amp to the soundcard? I can do it with the headunit but I have no headunit.
atrix415 is offline   Reply With Quote
Old 10-05-2009, 02:43 PM   #8
soundman98's Avatar
you need to tell us what signal level the bose amp is expecting-- we gave you the options-- if it takes line level, you only need to connect the pc directly to the amp, but if the bose amp needs speaker level, you will need to install a second amp to boost the signal to the bose amp. or you can remove the bose amp, and install a aftermarket amp.
Old 10-05-2009, 03:12 PM   #9
atrixstars's Avatar
I guess I am going to install an aftermarket amp that has rca input. So I guess I simply just plugged it into the amp rca from soundcard?
Old 10-05-2009, 03:49 PM   #10
MrZ
MrZ's Avatar
If you go that route, yes.
pc -> amp remote twry Car Audio 4 07-01-2008 07:01 AM
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 03:41 AM
Could my amp be bad or did i miss something? sansoo24 Car Audio 20 03-05-2007 02:45 AM
2 Channel amp no headunit skippy911 Car Audio 13 10-01-2005 01:14 AM
