Hi there,
I am installing a pair of 5.25" Focal 130V Slims into my MR2. Unlike the 165's, they are only rated for max 100w rms (165's are 150w RMS).
I am also going to run a single 10' shallow mount sub.
Looking to buy a GOOD amp to do the focals justice. Kicker have amps that can send a healthy 85w/90w RMS to the fronts, but, nothing against Kicker, I feel I should be spending more cash on a higher end amp to really make the focals come alive.
Rather than running a 2 ch, and then getting a separate amp dedicated to the sub (space is a priority in an MR2) I am thinking of going for a 4ch amp, that can have 2 ch to the focals, with a single bridged remaining channel able to send at minimum of 150w to the sub.
Will the Focal 4.75 manage this? What's the quality like of the Rockford Fosgate T400?
Any other recommendations?
In terms of shallow-mount subs - what is the 10' shallow mount Dayton range like? Also, Tang Band? Only reason I am asking is I have found a stereo place online that sells complete custom-built and designed sub + enclosures designed for the MR2.
Thanks for any of your help
