Old 10-01-2009, 09:20 AM   #1
13Beast is an unknown quantity at this point
4 channel or 3 channel amp???
Hi there,
I have a set of Focal 130V1's (5.25" slim) to go into my MR2. Its a small cabin, so I won't be running any rear fill, but do plan on getting a single 10" sub.
I want a GOOD 4ch amp to power the 130V1's (nominal rating: 50w, max: 100w), with the other 2ch to be bridged and feed plenty of juice to the 10" sub. I want SQ about SL.
The other alternative is to buy a 3ch. I want to stay with a single amp as an MR2 is VERY cramped, and I don't want to lose what little free space I have completely to my stereo. Looking to mount it under the seat (best place for it - given that I use my car on a daily basis, and regularly stow gear inside the car).
MR2's are very small cabins, so I don't think I should worry too much about going crazy on powerful equipment, just getting a good speaker and amp combo and a smart install and setup should do the trick and give me a very nice sounding system.
I have locked on to a few different models. I am after any advice or alternate recommendations as to my choices....
Focal 4.75
- I have heard these run hot, so am concerned about it being mounted under my seat. Also, can they be bridged into 2 channels running the fronts with a bridged channel for the sub (all at 4 ohms)?
Audison SRX3 or SRX4
- I have heard these are amazing, and I can source one a little cheaper than the Focal 4.75. I would lean towards the SRX3, as I heard it gets a little more power from its 3 channel setup, than the SRX4 bridged into a 3 channel (60w x 2, as opposed to 75w x 2). Is this correct?
Arc Audio KS300.4
- Maybe a little expensive for me. Again, wondering if they are really that much of a step-up in quality over the Audison/Focal to warrant the extra $$. I think they have a little more power, but I don't think I should need it with the speaker/sub setup... Opinions?
Cadence ZRS9004
- These are substantially cheaper than the other amps I mentioned. Not sure about Cadence products; I know very little about them. I believe they can be bridged into a 2 x 90w/1 x 250w setup. Should be plenty of power, but what's the SQ like??
Rockford Fosgate T400
- What's the quality like of RF's? They are about the same price (here in Japan) as the Audison stuff. Surely no comparison right??
Alpine PDX / MRP range
- More expensive than the Audison/Focal amps. Is it worth the price?
I also was considering the Kicker/Diamond range, but figured they may be a little low in quality to think of hooking up to the Focals. No disrespect to those brands, but I want the Focals to have a comparable amp in quality to give them good, clean power.
What other options are there to fit my application, with comparable quality and similar/cheaper prices to the amps I have mentioned?
13Beast is offline   Reply With Quote
Mono Or 2 Channel Amp? plurmaster Car Audio 4 02-05-2008 11:06 AM
Front or Rear out to 2 channel amp??? FrogDawg Car Audio 2 06-30-2005 03:49 PM
WTB: Decent 4 channel amp tiggs Classified Archive 2 02-19-2005 02:43 PM
Audigy surround 5.1out to 6 channel Amp !! GOOD lookinco Car Audio 19 11-25-2004 03:28 AM
6 channel amp? auto_robotics Car Audio 4 11-24-2004 02:33 AM
