Old 10-01-2009, 07:44 PM   #1
summer69guy is an unknown quantity at this point
asio question
now i am using asioforall wih vac
so like this the procssor get alot of work to do...
i would like to know if is there a way to use the asio which comes with my ASUS xonar d2
, to use less ressource n the cpu with on my 7.1 system. i'm using audiomulchl.
will it have a sound improvment if im using the xonar asio driver?
is there a step by step method?
Carputer:
Psu: DCX6.360-H
Mobo: Intel D945GCLF2
Ssd: ssd ocz solid state 30gb
ram : 1024 meg kingston 667 mhz
Sound card : asus xonar d2 pci
Fan : one nexus and one noctua
case : i'm building a new one
summer69guy is offline   Reply With Quote
Old 10-02-2009, 01:44 AM   #2
_Dejan_'s Avatar
_Dejan_ is an unknown quantity at this point
You can use ASIO in your drivers, BUT you media player must support ASIO. I think that your problem is not ASIO4ALL & VAC but your VST plugins, which take your CPU usage... Try with any other VST plugins...
_Dejan_ is offline   Reply With Quote
Old 10-02-2009, 02:00 AM   #3
thanks , for your answers.
i would like a method ..a how to,...of how to use the asio xonar driver(not asioforall)
i want to run mutltiple instance of some vst drivers...(many eq...2x time lsfilter)
and i want to know if i will get better sopund if it is processed by the sound card vs the cpu.
Carputer:
Psu: DCX6.360-H
Old 10-02-2009, 02:24 AM   #4
_Dejan_'s Avatar
VST plugins will allways be processed by CPU. For some serious audio setup you need good dual core CPU...
1.)Did you enable ASIO in AudioMulch?
2.)In device setup where you are select ASIO you have device which is now ASIO4ALL. Change ASIO4ALL to Xonar ASIO or something that. And this is all Also you must find best buffer setting for your setup(Sound without crackling ot pooping).
3.)In your soundcard settings route all WDM and MME sound into ASIO input(Im not shure if your car can do this). If you don't have this option you must use media player which can output to ASIO.
If you will not success make this read some manuals about ASIO and AudioMulch...
heavy-duty OBD standards support question Michael2006 Engine Management, OBD-II, Engine Diagnostics, etc. 0 01-07-2007 05:13 AM
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 06:15 PM
Forum Etiquette Enforcer Newbie 5 01-09-2006 06:58 PM
Paint And Polish Question gboy Fabrication 8 08-13-2005 08:22 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 10:03 AM
