Old 10-05-2009, 09:08 PM   #1
atrixstars's Avatar
atrixstars is an unknown quantity at this point
CAR AMP Harness to RCA connectors?
hi, I need to know if this works. From an old thread someone used a Metra 70-1725 connect to the AMP and get input from the soundcard. Can anyone please confirm. thanks
Quote:
are you trying to run the stock HU wit the carputer? if not go get a metra kit that will plug into your bose amp under the passenger seat that will convert it into rca's, then plug those rca's into the sound card of your computer. easy as that. i have an rsx too and currently working on carputer. let me know how you do.
Old Thread:
http://www.mp3car.com/vbulletin/gene...-you-pros.html
atrixstars is offline   Reply With Quote
Old 10-06-2009, 09:46 AM   #2
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
yes, that will work. it is very similar to the harness that i used in my eclipse-- you basically just need to attach the rcas to the sound card outputs, and connect the amp remote turn on wire to a switched source.
soundman98 is offline   Reply With Quote
Old 10-06-2009, 12:38 PM   #3
atrixstars's Avatar
thanks
Sound and car Amp question? carvolution General Hardware Discussion 0 07-04-2008 08:58 PM
psp to amp & RCA Y adapters roccomaniac General MP3Car Discussion 2 12-04-2006 11:34 PM
On a 2 channel amp that I plan on bridging, do I need BOTH rca ins? FyreDaug Car Audio 67 10-15-2006 09:35 PM
Answer to all your car's needs : never loose your car again! Romeo Input Devices 19 10-27-2005 12:53 AM
Advice on hooking up amp to stero harness - possible? 99bravada Car Audio 2 08-22-2005 05:37 PM
