Old 10-20-2009, 08:37 PM   #1
mm87 is an unknown quantity at this point
no sound help!
ok so i just got everything hooked up but no sound is coming out of my speakers
i got rid of the radio so i wired the remote turn on for my amp into my M2 atx 160w psu and the amp is turning on, but im not getting any sound. my guess is that its either a ground issue or a speaker issue but i cant figure out which one
for testing i only wired up 2 speakers and have my amp set on 2 channel mono bridged
help would be great
mm87 is offline   Reply With Quote
Old 10-20-2009, 09:38 PM   #2
also forgot to mention that i am using a usb sound card
Old 10-20-2009, 09:59 PM   #3
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
What type of amp are you using? Are you sure the amp is turning on? Is the computer setup to use the USB sound card, and the output is not muted? Ir you are using any audio processing programs, do you have the audio signal routed, and to the right output?
The more details you can provide the easier it will be for anyone to trouble shoot.
soundman98 is offline   Reply With Quote
Old 10-20-2009, 10:09 PM   #4
kross is an unknown quantity at this point
Start by hooking up headphones to the sound card output. If you get sound, then it's an amplifier turn-on issue. If you don't get sound, it's a PC configuration issue.
kross is offline   Reply With Quote
Old 10-20-2009, 10:46 PM   #5
tried out the headphone thing sound works..
what do you mean amp turn-on issue? i know my amp is turning on.. when the pc comes on a couple seconds later the power LED for my amp lights up. im new to this whole thing so if you could enlighten me that would be awesome.. thanks for your help
Old 10-20-2009, 10:51 PM   #6
its a rocksford fosgate 400w amp. the sound card is setup i made sure everything was setup before i put it in. i have my RCA routed according to the manual for my 2 channel mono bridged setup with 2 speakers hooked up. theyre plugged into the fronts. pretty sure its turning on since the power LED is turning on
edit: im actually starting to think its the RCA cable i used
http://www.bestbuy.com/site/olspage....=1181832400224
i tried going the cheap route here. should it still work or no?
Old 10-20-2009, 11:50 PM   #7
Quote: Originally Posted by mm87 View Post
for testing i only wired up 2 speakers and have my amp set on 2 channel mono bridged help would be great
Is this a configuration you've done before, and you know works? If not, how about trying something simple, like the normal, 4-channel configuration, and just use the front speaker connections for the inputs and outputs, leaving the rear connections unused for now.
That cable is fine. Cheap route? $13 isn't cheap, this is:
http://www.monoprice.com/products/pr...seq=1&format=2
Old 10-21-2009, 08:06 AM   #8
i was just going by what the manual called for since i have no actual radio
Old 11-07-2009, 05:05 PM   #9
Project07MACry's Avatar
Project07MACry is an unknown quantity at this point
Check your ground cabling. It may need readjusting. That was exactly what happened to me and my Camry...
Also, check your speaker cables for proper wire connection. And your RCA cables while you're at it.
Right now, I have sound coming from the rear only. And I feel it has something to do with the fact I used AM speaker cable instead of the Rockford Fosgate cables that I used for the rear.
Last edited by Project07MACry; 11-07-2009 at 05:08 PM. Reason: Adding in additional info...
Project07MACry is offline   Reply With Quote
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
iTunes vs Amp : sound quality natedawgg MacCar 5 05-10-2007 07:32 PM
Creative Labs Sound Blaster® Live!™ 24-Bit External USB 1.1 SpyderHatch Classified Archive 12 11-28-2005 05:12 PM
sound quality between carputer going through the HU and carputer going to amp lookinco Car Audio 9 08-07-2005 12:27 PM
got sound? masch Newbie 20 11-17-2003 10:01 AM
