Old 11-03-2009, 08:13 PM   #1
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
Help with amp issues!
A little about my setup:
- 2 x 12" Kenwood subs of unknown model. The only identifying marks on the visible part I can see are "Kenwood" and a big "W" in the center of the cone.
- Kenwood (claims 400W but idk) Amp KAC-748 (owners manual here: http://www.kenwoodusa.com/UserFiles/...als/kac748.pdf), 4 channel amp.
- Xenarc MDT-X7000 in dash lcd with AMP
The carpc outputs to the xenarc. The xenarc powers the 4 stock speakers and has 1 line out for the sub.
Looks like i have the subs connected to the amp via 200W each. IDK if my subs are 4ohms or 2 :-/
The problem:
before, i had the sensitivity output turned all the way up the bass power was good, but distorted at times. I turned the input sense down and now power output sucks. I can barely hear it. What do I need to do to get good power AND good sound?
LinuxICE - because my car already has enough windows (and because I like speed).
LinuxICE2 beta2 is released!!! get it now!
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 11-03-2009, 08:18 PM   #2
justchat_1 will become famous soon enough
Throw an ohmmeter across the sub terminals...even if you don't have the speaker model all you really need is the impedance.
Technically you have 100 watts per channel if bridged and 2ohm subs. Realistically this is a 35w RMS amp...not exactly a sub pusher.
openMobile - An open source C# Front End
- Currently Recruiting Developers -
Available for download on sourceforge
justchat_1 is offline   Reply With Quote
Old 11-03-2009, 08:43 PM   #3
PhilG is an unknown quantity at this point
if your measuring the "resistance" across the voice coil, you need to multiply that number by 1.3 to get an approximate "nominal impedance". for that driver. It really doesn't matter though, that amp is only capable of bridging to 2 channels so you are going to wind up putting one sub on each bridged channel anyways so "it is what it is". The amp is capable of a 2 ohm load so even if the subs were wound for 2 ohms (which I am sure they are not) your amp should survive. Make sure you have set the filters up right to knock down the high frequencies, or that will cause distortion. maybe you should consider only running 1 sub (if they are not mounted in the same box) and run 2 channels to the mid/high speakers. That would likely improve your SQ considerably.
http://philztruck.piczo.com/
PhilG is offline   Reply With Quote
Old 11-03-2009, 09:06 PM   #4
licensed to kill
kev000's Avatar
so a preamp won't help me? I'm leaning towards getting a new sub/amp set anyway. maybe i'll have to get it sooner than later.
Old 11-03-2009, 09:06 PM   #5
jessekilner's Avatar
jessekilner is an unknown quantity at this point
after reading the specs..lol, being bridged it only shooting @ best 50RMS but 35 is likley per sub RMS is the biggest factor as it's what 95% of your music listening is heard in. The peak is 100Wx2..PEAK this is considerably right on par as Just_chat said earlier.. as not enough juice for subs.. you will get bump on highest settings but your taxing that amp's ability and therefore the distortion is promininent. Just like a car would overheat under heavy stress...your amplifier is doing the same thing.
I would suggest a different amp for subs and use this one to power your compnents 6x9's and such
Did it.. Done it... now I got to keep the neighbors kids away!!
jessekilner is online now   Reply With Quote
Old 11-03-2009, 09:11 PM   #6
[QUOTE=PhilG;1353872]The amp is capable of a 2 ohm load QUOTE]
in 4ch not 2 channel notice they dont mention that...
Old 11-03-2009, 09:22 PM   #7
[QUOTE=jessekilner;1353876]
Yes, your right! I saw the line saying "Rated Power Output ( 2ohm) and thought that it belonged with the line above it saying 2 channel, but it actually belongs with the line below saying 4 channel LOL.
It's amazing though that this little amp is claiming a 28amp draw. It can;t be very efficient or its under-rated.
If a new mono block is in the cards to drive the subs, thats the way to go!
Old 11-03-2009, 09:27 PM   #8
Pre-amp may help you but so may a different configuration. If those are 4ohm subs they can be wired in parallel and deliver twice as much power. I would say the best option is to see where your starting from.
Old 11-03-2009, 09:32 PM   #9
Like we discussed above though, that amp is not 2 ohm stable unless ran in 4 channel mode, so that doesn't work
Old 11-03-2009, 09:40 PM   #10
I beleive he has it 4 ohm on each channel, I doubt those kenwwods are 2 ohm.. my Jl's are single 2 ohm but Im doubtful kenwoods are. Its just s simple matter of not enough power. reguardless of input range he sticks in it, it will only produce 100W Peak 35-50RMS per channel bridged and thats under the minimal operating range for the sub Im sure.
Old 11-03-2009, 09:41 PM   #11
I'm tired so I could be off but wouldn't a 2ohm load at 70 watts deliver more power then a 4ohm load at 100 watts (P=I^2R)? Granted thats peak...RMS would be equal but I would think that would still make a difference?
Old 11-04-2009, 04:26 PM   #12
licensed to kill
kev000's Avatar
The were originally wired in parallel. So they may just be 4ohm subs.
Old 11-04-2009, 04:43 PM   #13
soundman98's Avatar
soundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the roughsoundman98 is a jewel in the rough
...which would be a 2ohm load, and would cause it to overheat a lot, and cause it to shut off
my sony sub amp is the same way-- it is not 2 ohm stable, but i have hooked it up for fun in 2 ohm mode for 15-30 min and then it will go into thermal protection...
time to break out the DMM and double check.
soundman98 is offline   Reply With Quote
Old 11-04-2009, 08:56 PM   #14
Old 11-05-2009, 03:19 PM   #15
audiophyle_247 is an unknown quantity at this point
What is the crossover filter set to on the amp?
Ive seen people bring amps in because it sounded like **** when the problem was because they had the gain & bass up to max & the crossover set all the way down to 20hz.
The amp isnt a powerhouse, but Kenwood subs dont need a lot of power anyway.
audiophyle_247 is offline   Reply With Quote
Power Supply to Car amp Punkmanmatthew Car Audio 1 08-13-2008 11:56 PM
Can I run this amp with this sub, how do ohms work, help/recommendations... mikeym Car Audio 37 02-12-2007 12:10 PM
Amp running hot...?? Emerica2843 General Hardware Discussion 5 02-08-2006 06:40 PM
Amp running hot...?? Emerica2843 Car Audio 6 01-29-2006 08:29 PM
