Old 04-17-2004, 11:21 PM   #1
port20 is on a distinguished road
Car 5.1 Dsp Options Vs Pc 5.1 Dsp
There are only 2 useable mobile DSP’s that are compatible with PC’s the Audiobahn ADD51T & the Panasonic CY-AC300 EX or the older version the CY-AC300
First I will tell you why you need a mobile DSP versus a PC based DSP like the Extigy
Mobile DSP’s are engineered for harsh noisy 12 volt environments there power supplies
Are designed to block out the power surges and electrical noise from the alternator & ignition system
The RCA outputs are a minimum of 3 volts peak to peak because of this they block out 98% of the radiated noise and prevent & reduce the severity of ground loop noise that wine you hear from the ignition system & alternator in an automobile
PC based systems have a output of no more than 2 volts peak to peak & there power supplies have hardly any filtering they also use up computer resources & slow things down and often do not support Dolby Digital & DTS
Here are some terms that are often used incorrectly
Toslink is a connector used on some fiber optic cables but not all
SP/DIF is 1 a transmission protocol like USB & IEEE1394
2 it is also a transmission medium SP/DIF spec’s is a 50 ohm RCA cable also known as a digital audio cable
AC3 is an audio CODEC transmission protocol
Linear PCM also known as PCM is an Audio CODEC
Dolby Digital Dolby prologic I/II & DTS 5.1 are all audio CODEC’S
Here’s how it works
The computer gets the data form the DVD & sends it to a program like AC3 Filter witch extracts the codec you want say DTS then converts it to a AC3 stream and sends it to the sound card witch converts it to a SP/DIF data stream & sends it out the SP/DIF output or sends it out the fiber optic output as a SP/DIF data stream the SP/DIF signal sends the AC3 signal that is sending the DTS data to the processor where it is converted to separate analog signals kinda confusing I ain’t it
Here’s why other mobile DSP’s won’t work
The Audiobahn & Panasonic units are standalone units meaning they will work with any input that meets minimal requirements witch is a Toslink or Digital Audio cable sending a AC3 data stream they don’t require other equipment to work properly they also have built in volume controls other units require a stereo RCA signal to control the volume and it is not easy to run 2 sound cards on 1 PC and have both being used by the same program at the same time
The Pioneer DSP can be used if you use a pioneer head unit with it to control the volume
What you need to do is to cut the pioneer fiber optic cable & polish the cut end & then put it in a Toslink connector so you can plug it into a PC or SP/DIF to Toslink converter if needed
All other units Alpine Kenwood & so on can’t easily be implemented with a PC because of the volume control problem
port20 is offline   Reply With Quote
Old 04-17-2004, 11:45 PM   #2
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Yeah! Real information on Mobile DSP! I wish my bank account had more zeros on the left of the decimal.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 04-18-2004, 04:27 AM   #3
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Nice Info. thanks
antimatter is offline   Reply With Quote
Old 04-18-2004, 02:40 PM   #4
azcowboy is on a distinguished road
Yeah, but doesn't everyone wish that?
azcowboy is offline   Reply With Quote
Old 04-19-2004, 08:28 PM   #5
daiwilliamsuk is on a distinguished road
Thanks for the info port20
So if you are will to use a headunit from the same manafacture for volume control are any other dsps useable?
ie do they have Toslink or other easy to convert connectors?
Proper Planning Prevents Poor Performance
daiwilliamsuk is offline   Reply With Quote
Old 04-19-2004, 10:33 PM   #6
daiwilliamsuk here's your answer only with the pioneer
other units require a stereo RCA signal to control the volume and the toslink or spdif it is not easy to run 2 sound cards on 1 PC and have both being used by the same program at the same time
now if you can send analog and digital signals at the same time then you don't need a head unit
it is very hard and sometimes not possable to use 2 sound cards with the same program but if you rewrite the app to do so it could work
Old 04-20-2004, 05:43 AM   #7
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Thanks for the info. This was something I debated on how tyo implement.I was thinking about using the built-in Front L/R, Rear L/R and Sub outs going to a pair of amps (one 4-way for the Front & Rear and another to drive a mono subwoofer), and then call it a day.
I've done looking for mobile DSPs and you're right: they are few and far between. The ones that do exist don't have TOSlink capability for optimal data transfer. And the two options you presented aren't cheap.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 04-20-2004, 03:38 PM   #8
SoFlaLude is on a distinguished road
What about Alpine's PXA-H510 and PXA-H700?
SoFlaLude is offline   Reply With Quote
Old 04-20-2004, 07:47 PM   #9
thanks again port20.. You've saved me a lot of time and money!
Old 04-20-2004, 07:57 PM   #10
So would it be possible to use the stereo RCA output from a head unit playing any old cd to control volume? i.e. One audio stream from the computer (TOSLINK)to listen to and one from the head unit (RCA) for volume control.
Old 04-26-2004, 11:17 PM   #11
phatbimmer is on a distinguished road
so port, can i use the panasonic unit as my head unit? and control the volume and source from the panasonic unit. also, do you think there is any way i could wire my cd-rom directly to the panasonic rca input by using the analog outputs on the cd-rom that windows no longer uses?
phatbimmer is offline   Reply With Quote
Old 05-28-2006, 01:02 AM   #12
Memorex's Avatar
Memorex is on a distinguished road
I know Really old post but I intrested about this Audiobahn ADD51T. Most sites dont even carry it any more But i have a feeling there going to start to make alot more (http://www.audiobahn.com/Audiobahn06/pages/51606.html ) every were i look i get the same old picture and the same old discription and thats not really giving me the warm and fuzzys
Memorex is offline   Reply With Quote
Old 05-28-2006, 03:34 AM   #13
ChaCha's Avatar
ChaCha is on a distinguished road
Ditto. And the PXA-H701?
ChaCha is offline   Reply With Quote
Old 05-29-2006, 03:10 AM   #14
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
this thread is like 2 years old
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
How to power the PC OUTSIDE the car? msink Power Supplies 9 03-25-2004 12:52 PM
pc in car belmontboy Newbie 13 03-24-2004 03:48 AM
5.1 in a car? chewtoy General Hardware Discussion 12 10-16-2001 10:48 AM
My first shot at a mp3 car pc!!! radioman193 General MP3Car Discussion 1 08-16-2001 02:41 AM
About power Supply to PC in car Sk8te General Hardware Discussion 2 11-11-2000 11:39 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
