The MP3car.com Store
Thread Tools Display Modes
Old 06-03-2004, 09:34 PM   #16
Vehicle: 93:87/SHO:GTI/Ford:VW
My Photos: (0)
rember one thing, EQ's (little known fact) are only made (its main goal) to cut levels not boost, turning its gain down and not boosting your 400khz and up freqs. will and probaly would have removed most of your noise before doing anything else. one important thing to do most techs in my idustry dont get or understand is case grounding all componets. that means running a wire from case screw of the reciver to case screw of your amps, computers, eq's etc
14.4vTech is offline   Reply With Quote
Sponsored Links
Old 06-05-2004, 03:39 AM   #17
gubon13's Avatar
Vehicle: 1997 Ford F-150
My Photos: (0)
agreed - grounding is as important as the power input, but people just seem to cheese it a lot.
btw, what industry are you in? only thing that came to mind when i thought of 14.4v was my cordless torque drill...
"Is Wayne Brady gonna have to choke a b@$#*??!!"
gubon13 is offline   Reply With Quote
Old 06-05-2004, 05:15 AM   #18
Vehicle: 1992/Honda/Integra(LS)
My Photos: (0)
do you mean grounding all the equipment (eq, amps etc..) together and THEN grounding it to the car? or only grounding the equipment without grounding that to the car?
JayKaye is offline   Reply With Quote
Old 06-08-2004, 11:08 PM   #19
My Photos: (0)
LMAO ive been a Mechanic (auto) my Passion and main income comes from audio video installs in cars, also do some home theater but preffer cars, I am also a consultant for a company thats making mobile computers for cars.
The last three years I wa working in a high end shop mainly working on late modle Bentleys, porche, BMW & BENZ
Oh and your cars system is supposed to charge at 14.4 volts, unseen number for the most
Ground all your componets the way they are supposed to be grounded, then run a wire from the head unit case to the next coments case and from that case to the next it creates more of a stable common ground, all your componets ground to their case.
Good reading here for you all to lear about GROUND LOOPS
http://www.epanorama.net/documents/g...oop/index.html
Old 09-08-2006, 04:14 PM   #20
My Photos: (0)
did u ever figure out that engine noise? My car was doing the same thing on the right side of the front end and come to find out it was a bearing in my tire that needed to be replaced?
jetta02 is offline   Reply With Quote
Sponsored Links
Old 09-09-2006, 09:45 AM   #21
My Photos: (0)
Way to dig up a 3 month old topic.
Shadow is offline   Reply With Quote
Old 04-07-2008, 11:00 AM   #22
My Photos: (0)
noise
Quote: Originally Posted by JayKaye View Post
um, any help please?
ground the shields of the rca cables on the back of the radio to the radio.cut a little of the cover off of the left and right channel rca to exspose the shield of left and right channel,take another piece of wire and wrap around both rca grounds and tape up.take other end of the piece of wire u used and put under a cover screw on radio,now it should have no noise.mike
vs420michael is offline   Reply With Quote
Old 05-31-2008, 09:51 PM   #23
My Photos: (0)
hehe, post originally made 4 yrs ago.... well my next carputer install (coming up in a month or two) ill keep that in mind! thanks :P
- VIA EPIA M10000
- 60GB, 256RAM
- 7" TS Lilliput in TM-701L
- 802.11g
- GPS
- Remote PC start and hibernate
- 2nd "tank" battery
- 4-port USB hub 'in-dash'
- Media Engine
- 2 amps, 2 subs, 4 spkrs, 1 eq
[||||||||||||||||||-] 95% complete
Old 06-01-2008, 05:08 AM   #24
FPeter's CarPC Specs
FPeter's Avatar
Vehicle: 2005 / Opel / Astra H Z17DTL
My Photos: (7)
http://mscbp.hu/ProductDetails.aspx?ProductID=223
5500HUF+VAT = ~32$+VAT
FPeter is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Noise on audio from laptop pip Laptops, Tablets, UPMCs, etc. 6 11-24-2006 07:09 PM
Group buy for the cheap MagicPower 120W MPD-810H DC-DC PSU Telek Power Supplies 86 04-04-2005 03:57 PM
Damn Noise Freeman General Hardware Discussion 3 03-20-2004 12:37 AM
Engine electrical noise Dimitris1976 General Hardware Discussion 9 10-17-2001 11:24 AM
dc-dc and engine noise Harvester General Hardware Discussion 4 11-05-1999 05:31 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
